586,082 active members*
3,836 visitors online*
Login Register
Siemens Digital Industries Software Forum
Where today meets tomorrow.
Milling > Some effective tips to save on CNC machining parts
Results 1 to 2 of 2
    Post Some effective tips to save on CNC machining parts
    Re: Some effective tips to save on CNC machining parts
    materials from a reputable supplier cost the same when buying a hundred feet or a few thousand feet . If your buying direct from a mill then the price will be reduced with the more you buy to a certain level , but , mill direct requires minimum order amount which is quite high . A shop that carries a regular high volume of stock may benefit by paying attention to the commodity prices and purchase accordingly
    Higher cost savings would be better found in castings , forgings , and custom extrusions , all starting with a high initial material cost which pays off with reduced machine times and waste . This mostly applies to high volume production .
    Materials are generally chosen based on their physical properties and how they apply to the application the parts are being made for . This is usually an engineering department decision which is often ignorant of how the parts are processed . It is very often that machinability isn't a consideration . It becomes a possibility when the manufacturing section proposes a free machining alternative which will provide similar properties to the chosen material for the job . This is either shot down immediately by the engineering dept or requires weeks if not months of research and testing by the engineering dept . Time is money and the people at their desks know more than the shop floor , so shot down is the most common occurrence
  1. Make your custom-designed CNC parts easier to produce and cost-effective
    By RapidCNCMachining in forum Manufacture Company Listing
    Last Post: 07-28-2021, 03:33 PM
  2. Make your custom-designed CNC parts easier to produce and cost-effective
    By RapidCNCServices in forum News Announcements
    Last Post: 06-10-2021, 03:16 PM
  3. Replies: 0
    Last Post: 03-13-2018, 06:33 AM
