I've only machined a couple of small pieces in Delrin, but it's fantastic to use fast, quiet, gigantic chips that are easy to clean and pick up. Love it!
Digital Industries, Motion Control, Machine Tool Systems
Hi, great thread!
I just received my PM45 today, and am looking to convert it to CNC as well. Do you still have the CAD models? I'd love to get my hands on them, it would save me a ton of time measuring mine up
Could be worth trying lower RPM as well, for hopefully less heat and tendency for chips to stick/weld themselves to the tool?
Yeah as Jess said there earlier and rlockwood too, I too use flood coolant all the time in my BF20 which hasn't even half the capacity of your build and even yesterday I was using a four flute endmill to profile cut a part out of a larger stock piece (and also without widening the cut) so basically it was similar to an awfully long slot with curves and corners....and yes as was suggested earlier a two flute would definitely allow for easier chipload removal...in my humble experience with a smaller mill and lower capacity I can still achieve pretty good high end cutting speeds with flood coolant. .....
Eoin
Pretty sweet compressor man. I love how silent it is. For others with a traditional 5HP 2 stage compressor if you move the intake to say out side or even in the attic and put a large filter like the old school cheap ones on muscle cars it really drops the noise a lot. You would be surprised how much noise is actually coming from the inlet of the pump.
I love your expression after you hit the vise. I say the same stuff. I haven't hit the vise yet, but their are times it sure is close.
Jeremiah
PM45 CNC Build in Progress
Ugh! Amazing.. where to begin.. Awesome car, sweet mill and conversion, amazing gun (btw i'd love to get into that, sport shooting). Gotta give credit, where its due. Attention to detail and quality, very nice job. You mentioned where to go local for tooling. Right in Auburn, I've been numerous times to http://www.1asi.com/.
Application Specialties. They supply a lot of the Boeing suppliers and shops in the Puget Sound. Really nice guys. Be warned you will leave about 100 pounds heavier with free brochures, and tool magazines. Some of there stuff, is top quality and really out of the price range of the hobbyist. There economy endmills, are still probably better than anything youll find from little machine shop though. They are really well priced also for the little stuff. They also resharpen bit for cheap, and can pretty much get ahold of anything you need. Anyways, amazing job keep up the good work. I'm in the process of getting my little machine shop X3 going, so im sure in the future youll see me asking for help haha. Anything you need feel free to message me. Nice to know people locally!
Can't wait for more updates!
Haven't mounted the new vises, but I did make a little progress on my new gun I'm building. I did a poor job fitting the rails the first time, so I weld them back up with the TIG and programmed the toolpaths instead of doing it with MDI and no plan like before.
Welded up and ready to go.
Toolpaths
Cutting
STI 2011 Frame Fitting - CNC - YouTube
PM-45 CNC conversion built/run/sold.
Wow, great job on the machine and what you're doing. I found this thread from Straightup_OG's on the Bverse. Thanks a lot for all the detailed description and photos. Very helpful for a newb like me.
Kevin
Thanks. Heading out to build a barrel holding fixture and then profile cut the lower lugs.
Nice thread. 2011's are fun.
Fixture all machined. My spindle has the random dip in speed, who knows why, but you can hear it happen in the video. Did some slotting with a 1/2" 3 flute, went well until the very end of the operation where one flute starts to clog while ramping down into the 2nd level. I just let it go. I guess slotting is really a 2 flute deal. But it did run nice at .20" DOC, 6800 RPM and 42 IPM. Next time I slot I'll move to 2 flute and up the DOC to .25".
I bought a couple CAT40 ER20 holders and some pull studs for Haas and Hurco. That gives me a few of my own tools for testing machines!
Making a 1911 Barrel Holding Fixture - YouTube
VERY nice!!
I'll add some text later....
1911 CNC lower lug cutting - YouTube
More
Open Gun Slide Work Part 1 - CNC 1911 Slide Lightening - YouTube
Niiiiiice.
Which red dot are you putting on there?
