587,459 active members*
3,468 visitors online*
Login Register
SolidCAM Forum
Fadal > Fadal 5 axis, trouble with B axis/possible dnc
Results 1 to 6 of 6
    Dec 2015
    14
    We just got out 5 axis fadal 4020 home, it has a 88hs control. We are using multi dnc to send g code. We struggle to get multi dnc to work, but found We had to delete the information that it was adding to the start of the code, and add "dnc" to the start of the code. Our code is in absolute, and we are having a strange problem, when it calls to move the B axis, it goes past where is should be and will try to crash into the table. Any suggestions or experiences would be a great help.
    Feb 2006
    992
    Re: Fadal 5 axis, trouble with B axis/possible dnc
    Quote Originally Posted by sledhead306 View Post
    Never use Fadal before, but Use to run Haas and there is support a option is the setting you should turn on while machine run. Any B axis move beyond the setting will get alarm.
    The best way to learn is trial error.
    Oct 2017
    4
    What i found out with the DNC to work good at least with my machine is
    to take the good baud rate and also tell the little card what the baud rate is before i did that it would not work reliable.
    ihavetheCALMOTION LANCNC-FADAL MEMORY INTERFACE
    i dont know about the code its adding maybe thats something you can change aswel ?
    i hope this wil be of some help
    Jun 2011
    32
    The Fadal 5th axis requires signed motion commands in absolute or incremental. Any move from the current position clockwise (from the operators view) is in a minus direction and must be preceded by a - sign. Any move counterclockwise from the current position is is positive and does not require a sign in front. All commands must contain a decimal point.
    For instance, if you want to go from having the rotary axis horizontal at B0 to having it vertical, you must command B-270. If you command B270., it will try to move in a positive direction (CCW from the operator's viewpoint) and crash into the table.
    If you are at B-270., for instance, and want to move CCW by 15 degrees, you would command B285. If you then wanted to move CW by 3 degrees you would command B-282.
    If you get into full 5 contouring, I have found it best to program from the centerline of rotation for A&B for the best results.
    Hope this helps.
    Quote Originally Posted by motogomi View Post
    Hope this helps.
    hi
    thx for your information
    can i change format to -360*+360 for direction rotation instead 0to 360?
    Jun 2011
    32
    Unfortunately, no.
    That type of setting is in hardware (eprom) and not accessible to the user.
  1. Trouble cutting circles. Trouble with y-axis
    By chrisv7 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-08-2016, 09:43 PM
  2. A Axis Trouble
    By Jam10207 in forum Community Club House
    Last Post: 09-18-2013, 08:17 PM
  3. trouble with x and y axis
    By racerx81 in forum Mach Software (ArtSoft software)
    Last Post: 09-02-2013, 09:08 PM
  4. X-axis trouble
    By sihtamsivart in forum DIY CNC Router Table Machines
    Last Post: 11-07-2012, 12:35 AM
  5. Axis trouble...
    By Squid in forum Mach Mill
    Last Post: 08-01-2012, 06:34 PM
