587,204 active members*
3,092 visitors online*
Login Register
SolidCAM Forum
MetalWork Discussion > CAD drawings of most popular V8 engine bellhousing patterns - Page 4
Page 4 of 5 2345
Results 61 to 80 of 87
  1. #61
    Aug 2017
    Re: I have some Mopar drawings
    Quote Originally Posted by freefuel View Post
    I have both the small and big block Chrysler bellhousing drawings, plus the slant 6.
    I also have a really fuzzy photo of an AMC V8 blueprint, but it is readable!
    I also have some nice drawings of 4 and 5 cylinder Volkswagen TDI Diesels.
    PM me your email address and I'll send them to anyone who wants them, I'm not interested it setting up a photo hosting account.
    Lastly I'm searching for a BOP Buick/Olds/Pontiac/Cadillac bellhousing bolt pattern drawing.
    P.S. I have a spread sheet listing a pattern for the Mercedes OM617 5 cylinder Diesel
    Hi , is there anyway I could get the small block mopar bellhousing drawing ( LA ) ? I am making a adapter plate to go from
    a Isuzu 4bt1 to a 727 trans
    Thanks Bruce
  2. #62
    Jul 2010
    24
    Quote Originally Posted by Valleyghost View Post
    Thanks Bruce
    Hi Bruce send me your email address and I'll forward the zip file with the drawings to you.
    Justin
  3. #63
    Jun 2018
    Hey archangel,
    Could you send me the bellhousing blueprints for a 2003 4.6 V8. I want to be sure I have the right one. Thanks!
  4. #64
    Dec 2018
    Re: CAD drawings of most popular V8 engine bellhousing patterns
    hello, any dimensiones of Cummins Allison adaptar
  5. #65
    New guy here. Thank you freefuel for your small and big block Chrysler drawings.
    Does anyone have the 6 bolt crankshaft drawing for a big block, 383-400-413-440 Chrysler?
    Many thanks. Engine swaps are fun...
    G.
  6. #66
    I need the 440 cast crank 6 bolt flange drawing. Forged 6 bolt drawing would work as well.
    Thank you.
    G.
  7. #67
    Jan 2017
    Does anyone have the inner/aft bell housing bolt pattern from a 4l60e? Looking to make an ar5 adapter using the removable bell housing from the 4l60 to bolt to an LS motor. Thanks!
    Sent from my SM-G955U using Tapatalk
  8. #68
    Dec 2005
    504
    Does anyone have the bellhousing bolt hole pattern/dimensions for a Ford FE big block? Even just knowing the dowel pin locations off center line would be great.
  9. #69
    Jul 2019
    I'm looking for the bell housing bolt pattern used on early 90's AMC 4.0 L6. I am making an adaptor that will make a VW TDI look like that engine so I can put an AX15 trans on it. Crankshaft adaptor is designed, but having issue verifiying the bell adaptor short of buying a bell and measuring. Is this thread still active?
  10. #70
    Sep 2019
    Hi ARCHANGEL, If I could get a copy of the 460 BBF rear engine pattern that would be greatly appreciated. I have to make a mid plate for a race application.
    Thank You
    Paul
  11. #71
    Jan 2020
    Did you ever find a schematic for the 220 Bell housing ? I want to adapt the GM 700 r4 to mine.
  12. #72
    Lookimg for the bolt pattern for a 5.0 Coyote V8, it shares the same pattern for the 4.6 and 5.4 ford modulars. I don't know if im doing something wrong, but i couldnt seem to access it here. Thanks in advance.
  13. #73
    Hi, my drawing on the rear of the BBF has been damaged and can no longer read the right side of the drawing from the top bell housing bolt down to the starter pocket. If anyone has a drawing hand or CAD if would be greatly appreciated.
    Also looking for the front bolt hole dimensions and size for the GM LS engines and the Ford 4.6/5.4...
    Thanks in advace
  14. #74
    Jan 2007
    146
    Is supposed to be a 460-429 drawing that I collected years ago.
    Attachment 439438
  15. #75
    Sep 2020
    Hey there
    Maybe a long shot, but..
    The plan in to mate a B230 Volvo redblock with á GS6-37DZ from a 530D BMW.
    Is there anyone out there with some blueprints of either bellhouse?
  16. #76
    Oct 2022
    Hi, new to the forum. I'm looking for the bolt pattern for the universal bellhousing that fits both Buick and Chevrolet. I'm wanting to make an adapter for a 200-4r transmission to a 1951 Chrysler flathead 6. I could use either the Buick or Chevrolet pattern as a starting point.
    I would also like the flexplate to crankshaft bolt pattern if someone has it.
    Thanks,
    Ken
  17. #77
    May 2023
    I have the sb Chrysler pattern you are asking for and in trade I sure would like to see that OM617 pattern and the BOP pattern.I could not attach anything to it how would you like to do this?
  18. #78
    Nov 2023
    Hi All,
    First time poster here after finding this page. I have a transmission dyno and I am currently updating my faceplate on it to add provisions for some new bell housing patterns.
    I am after the following patterns/drawings if anyone can help:
    Ford Y-Block
    Ford Windsor 5 Bolt
    Ford FE 330, 352, 390, 427, 428
    Cadillac/Pontiac 429 (used in 1964)
    Dodge V10 Magnum
    Any help would be greatly appreciated.
    Thanks,
    Paul
  19. #79
    Feb 2024
    Seems this thread may still be active...
    Anyone that has bellhousing patters for domestic engines, I'd like copies. I could use the information for a few books I'm writing (I'd be particularly interested in dimensioned drawings for IHC I6 & V8 engines as used in their lighter trucks - through about Class 3/Class 4. (And, if anyone has a list correlating line code/option numbers to actual part model numbers, that would be fantastic!)
    JonDKelley TA gmail TOD com (just in case the email scrapers are starting to get wise to breaking up addresses. I really need to make another image of it...)
    JDK
  20. #80
    Apr 2005
    460
    Re: Yanmar L100 drawings
    If I'm not mistaken its 460 but with different Dowel Pin Size
Page 4 of 5 2345
  1. Popular presents.......
    By MarkusD in forum Portfolio Board
    Last Post: 02-13-2014, 01:29 PM
  2. What will I make Is the popular question...
    By milhead in forum CNC Wood Router Project Log
    Last Post: 02-08-2012, 12:40 AM
  3. Big Block Chev Bellhousing Dimensions
    By hellcycledoctor in forum Australia, New Zealand Club House
    Last Post: 03-30-2010, 11:27 PM
  4. drawing board drawings to cad drawings
    By mike hide in forum Uncategorised CAM Discussion
    Last Post: 03-23-2009, 10:35 AM
  5. single cylinder engine drawings?
    By savvypower in forum MetalWork Discussion
    Last Post: 02-01-2007, 12:44 PM
