588,375 active members*
9,235 visitors online*
Login Register
SolidCAM Forum
Solidworks > Help with complex mold creation
Results 1 to 8 of 8
    Nov 2007
    4
    Hi, I have made a model of a MK 1 Tiger Tank track link at 1/8th scale that I've built in solidworks. I'm trying to to create a mold for this in solidworks so I can machine it in steel and then use that to cast 200 links. I've never done any mold design before and this shape is particularly complicated. Is anyone on here a wizard with solidworks who could give me a hand. The demos look simple but this is going to need to be in more than two parts.
    cheers Paul.
    Jun 2008
    562
    Re: Help with complex mold creation
    Can you post the model?
    Nov 2007
    4
    I've put a copy here www2.mrc-lmb.cam.ac.uk/track.SLDPRT.zip
    cheer Paul.
    Jun 2008
    562
    Yes the mold will have to have side core pulls to get the holes. You are also missing draft and split lines in quite a few spots. It would take 5-8 hours to get a rough mold of the part and I don't have a lot of free time to give right now. There are some Solidworks tutorials on the web that could help you.
    Good Luck
    Mike
    Nov 2007
    4
    I'm not really worried about the holes as they can be drilled. But I think it's going to need multiple parts to get the shape. I've looked online but I've not managed to find anything that shows how to put the correct parting line in. It's not clear to me where the best place to split the model is because I have no experience in moulding and have only been using solid works for two weeks to built the track. Anyway thanks for looking.
    Jun 2008
    562
    I think you can mold it in one piece. Just remember you can't mold with undercuts.
    What material are you molding?
    Nov 2007
    4
    I want to machine it in steel and then cast it in aluminium. It needs to be in at less two pieces possibly three or four.
    Jun 2008
    562
    With aluminum, you will need ejector pins, and draft on all vertical walls. Don't forget to add shrinkage to your mold steel if your tolerances are close
  1. Replies: 0
    Last Post: 08-29-2014, 12:45 PM
  2. Replies: 4
    Last Post: 12-30-2013, 12:16 PM
  3. Replies: 0
    Last Post: 07-13-2012, 08:27 AM
  4. Best way to prep mdf mold for making female mold
    By konalure in forum Moldmaking
    Last Post: 10-29-2009, 02:48 PM
  5. Making a positive mold from a negative mold - how?
    By SRT Mike in forum Moldmaking
    Last Post: 03-29-2007, 10:30 PM
