586,065 active members*
4,747 visitors online*
Login Register
SolidCAM Forum
Phase Converters > Fuling inverter DZB300 or DZB200
Results 1 to 9 of 9
    May 2017
    23
    Hello buddies,
    I lost my fuling inverter DZB200 series because of uppervoltage (Electricity in Cameroon is a mess).
    I ordered a new one but the seller sent me a DZB300 series. Can I use it with my 1,5kw soindle ?
    If yes, how to set the parameters ?
    I count on your answer because I am afraid of any misuse.
    Thanks in advance
    15362
    Re: Fuling inverter DZB300 or DZB200
    Quote Originally Posted by bivegele View Post
    Hello buddies,
    Thanks in advance
    Sure if the VFD has a Kw Rating that suits your spindle, the old one most likely failed because of wrong Parameters set
    So if you have the VFD to Match the Spindle there will be no problem no matter what model the VFD Drive is
    Spindle spec's
    Kw 1.5
    Amps=??
    Hz=??
    Voltage=??
    VFD Drive spec's
    Voltage=
    Amps= output
    Mactec54
    Salut bivegele je suis au Cameroun et j’ai un problème avec mon inventer dzb300 je l’est configuré mais ma broche ne tourne pas. Comment faire?
    J’aimerai avoir ton numéro voici le mien +237699570073
    Mar 2009
    1982
    conect the motor directly without the inverter.
    15362
    Quote Originally Posted by Algirdas View Post
    How could you post such a thing without knowing the motor spec's
    Mactec54
    May 2017
    23
    Thanks for your concern. These are the informations about my VFD and my Spindle :
    Spindle spec's
    Kw 1.5
    Amps = 5 A
    Hz=400
    Voltage=220
    VFD Drive (Fuling brand) spec's
    Voltage= 220
    Amps= 7.0 A
    Can I get the procedure to restore default parameters of the Inverter. I want to reintroduce the correct settings to the VFD in case it could solve the problem.
    - - - Updated - - -
    Bonjour Fabrice. Vous avez quel type de machine ?
    - - - Updated - - -
    Mon numéro est le +237694438248
    May 2017
    23
    I apologize for that oversight. Thanks for your concern. These are the informations about my VFD and my Spindle :
    Spindle spec's
    Kw 1.5
    Amps = 5 A
    Hz=400
    Voltage=220
    Voltage= 220
    Amps= 7.0 A
    I must say taht after introducing all the parameters in the VFD, the spindle doesn't turn even when I try to lanch it by command in NCStudio.
    15362
    Spindle spec's
    Kw 1.5
    Amps = 5 A
    Hz=400
    Voltage=220
    Voltage= 220
    [COLOR=#000000]Amps= 7.0 A
    F0.12=1 will restore the Drive Default Parameters, you will then have to reset the Parameters for your spindle specs
    Mactec54
    May 2017
    23
    Thanks a lot Bro. I right now go to my workskop to do that.
  1. Fuling Inverter DZBSeries
    By gerardo.pellice in forum Phase Converters
    Last Post: 08-09-2022, 05:27 PM
  2. Replies: 0
    Last Post: 08-28-2014, 01:51 AM
  3. SEtting Fuling DBZ200 Inverter
    By regpugh in forum DeskCNC Controller Board
    Last Post: 03-28-2014, 11:51 AM
  4. Fuling Inverter spindle speeds and feed rates
    By alanstclair in forum Chinese Machines
    Last Post: 07-17-2012, 11:21 PM
