586,072 active members*
4,729 visitors online*
Login Register
SolidCAM Forum
CNC Machining Centers > Panelmac alarm code
Results 1 to 6 of 6
    Panelmac alarm code
    Hi. New here but have read a lot. We have been curious about the cnc world for a long time and recently happened to come across a better used scm tech 80. We read a lot in the manuals etc. But last Friday when we turned on the power and thought to start testing, there was a stop immediately. We were going to do a calibration but we did not succeed. The following message appears in the panel mac.
    PLC5: Axes brushless fault drive
    PLC: Machine emergency
    We have checked all safety switches, ropes, doors etc. Does anyone know what that means?
    Thanks in advance
    Re: Panelmac alarm code
    Now we have managed to get past and calibrate the machine. But when we were to run a test, it hung in the tool switch instead. So now we are wondering instead if anyone knows how to force the machine to some kind of origin. We did not have a holder in the spider. and guess that's what triggered a stop instead.
    I'm just waffling here. But if anyone knows, we would be happy.
    thanks
    I jerked past the safety loop. Then I managed to move the machine and close the magazine via MDI. And hoped it would remove my error message. But that was not the case. But I failed to make a tool change via MDI. Don't get wise to this.
    PLC76
    And again, the following has also emerged. It is these codes that I removed earlier.
    PLC4
    PLC5
    Jan 2015
    35
    it could be that tool changer is still opened or main spindle is not in up position
    Quote Originally Posted by mobelsnickaren View Post
    PLC76
    PLC4
    PLC5
    Hello, I just have the same problem, did you already solve it?
    Do you know how can I get pass thru the "emergency stop"?
    Nov 2022
    Hello, I’m using SCM tech z5 cnc. I have a problem my machine is not moving can you help me? I got a plc4 code pls help me with this.
  1. Need Help - Amada RG 80 Error code 315 / Alarm code 315
    By P2CNC in forum Maintenance DIY Discussion
    Last Post: 04-18-2021, 06:58 PM
  2. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  3. Can I tell how many linear feet a bit has cut? Morbidelli 636 and PanelMAC
    By jkcreative in forum Commercial CNC Wood Routers
    Last Post: 02-03-2017, 02:38 PM
  4. xilog e panelmac con masterwood310
    By desmos79 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-18-2013, 11:45 AM
  5. HELP QT 350 alarm code 371 turret servo alarm
    By kirkmach in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-19-2011, 09:39 AM
