586,119 active members*
3,586 visitors online*
Login Register
SolidCAM Forum
Spindles / VFD > Spindle Teardown
Results 1 to 3 of 3
    Apr 2020
    23
    Spindle Teardown
    Hi Folks!
    I'm mid-way through a bearing replacement on a Colombo spindle and am a bit stumped (yes, I'm aware this is something that's typically done by a shop) . The teardown until this point has been pretty straightforward but I'm at a point I can't seem to get past. I've attached photos of progress, I believe my next step is to remove the pin-wrench style lock nut on the very top of the shaft at this point (the wide nut with two holes). I've given it a lot of muscle in either direction with no love, as well as some whacks with a hole punch as hard as I care to without damaging it with no movement. If this looks familiar at all to anybody I would very very much appreciate any tips. I'm happy to mangle the lock nut and replace it on reassembly, however I'm concerned there's a possibility it is a clockwise removal. Any tips on this step or any others are very appreciated! I'm at a bit of a loss.
    Spindle is Colombo RA RC 135.22
    Thank you
    https://ibb.co/t8SD4hn
    https://ibb.co/60W3Vh7
    Apr 2007
    66
    Re: Spindle Teardown
    Hello...I have just started to take mine apart. Have ypu had any luck with yours. Do you have a manual?
    Let me know how it is going?
    Apr 2007
    66
    wow...i see this is a old post.....well if you see this maybe you can give me some pointers.
    Thanks,
    Ben
  1. Power Drawbar cylinder teardown?
    By yugami in forum Milltronics
    Last Post: 05-11-2018, 02:12 PM
  2. Complete teardown and rebuild of the SX2
    By J S Machine in forum Benchtop Machines
    Last Post: 08-31-2011, 02:18 PM
  3. Large format printer teardown
    By agonsw in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 12-07-2010, 04:02 PM
  4. Servo motor problem after teardown?
    By altered in forum Servo Motors / Drives
    Last Post: 04-22-2007, 08:48 PM
