586,103 active members*
3,562 visitors online*
Login Register
SolidCAM Forum
EDM Discussion General Topics > Cutting taper with Fanuc Robocut
Results 1 to 18 of 18
    May 2010
    61
    having a problem cutting tapers on this machine. New to it all and am learning but... I cut one on a test piece one time but it didn't cut like I wanted. As in it set the taper on the first move which was one I needed the taper to be set before cutting it. I've since learned how to go about that but now the only way I can get it to cut one is on Mode 10 with me programming the U,V. The last one I used Mode 1 and just added a G52 Code and it worked but now I'm getting a Error 40 code which is programming I think.
    Gonna post pictures of my program and the settings and ask if someone will look at it and tell me what I have wrong. I'm sure it is something simple but I'm just not finding it. I've got the books and from what I can see it is written right and the taper info is correct.
    Attached Thumbnails Attached Thumbnails 271542338_1544884102561052_2331218244780876228_n.jpg   272156545_503961537721192_1083180572630848351_n.jpg
    Aug 2008
    406
    Re: Cutting taper with Fanuc Robocut
    Quote Originally Posted by tlmkr38 View Post
    I have an older Fanuc wire .I also have to command a G41 or G42 offset in the program and at the end G40 G50 X0 Y0 ,,,U0 & V0 ...You also have to set your guide position correctly .What wasn't correct the angle ?
    May 2010
    61
    Re: Cutting taper with Faunc Robocut
    I haven't gotten it to run yet. When I try to run the program I get a error 40 code which the book says is a programming error. Once I get the program to run I'll look at the settings for the guides to get the angle correct. I know I tried it with the offsets in there but maybe I had something wrong. I'll try it again. If you can see something that isn't written right I would appreciate it if you could fix it and post or at least tell me what it is. I can cut straight lines and all using 4 axis programming and setting 10 on the taper settings but I am going to have to cut die clearance tapers on some radius's soon and I'm not real sure how to do that in 4 axis. Have a friend who runs EDM's coming this weekend so maybe he can help. Any help is appreciated Thanks!
    Aug 2008
    406
    I checked the code and your end point for the arc is not correct .Bad G-code . I always make sure you can run the the profile first then add the G51 or G52 and you T angle .Your format looks strange also . It should be program number then G92 X0 Y0 Then G90 then g41 or g42 and the goo or go1 move command last line should be g40 g50 xoyou0v0 them m30.Good luck sir.
    May 2010
    61
    Here is a copy of the program I just cut and pasted. It was written in Incremental and with out the taper in it it runs good. I just run it to make sure it would as I couldn't remember. However, when I put the taper offsets and info in it I get a error 40 alarm. It makes a hole that looks like a keyhole with the straight part being 0.150" wide at the bottom. Sorry about the confusion, I should have been more specific
    O8003
    M15
    G91
    G92 X0.0 Y-0.125
    M86
    G1 X0.0 Y.125
    X-0.075
    Y0.208
    G2 X0.15 Y0.0 I0.075 J0.238
    G1 Y-0.208
    X-0.075
    Y-0.125
    G90
    G0 X0.0 Y-0.5 U0.0 V0.0
    M30
    Thanks again for any help.
    Aug 2008
    406
    O8003
    M15
    G91
    G92 X0.0 Y-0.125
    M86
    G41
    G1 X0.0 Y.125G51T3.0
    X-0.075
    Y0.208
    G1 Y-0.208
    X-0.075
    Y-0.125
    G90
    G0 X0.0 Y-0.5
    G40G50X0.0Y-.125U0V0
    M30
    TRY SOMETHING LIKE THIS.
    Mar 2016
    325
    i checked Manual, and error 40 refers to invalid data for taper cutting, to check guides distances, part thickness and ref. plane.
    Aug 2008
    406
    re: Cutting taper with Fanuc Robocut
    Try making your lower guide height a negative number .
    May 2010
    61
    Thanks! I'll try it once I get this job out of the machine. I know it''s something I am doing wrong so hopefully something will work.
    May 2010
    61
    Quote Originally Posted by gabedrummin View Post
    I'll look at that also. I never changed it on the settings as i measured it and it was where it needed to be however, if it is supposed to be a negative I may have changed it somehow and not realized it.
    Aug 2008
    406
    DId you get this fixed ?
    May 2010
    61
    I have not. I haven't been able to mess with it a lot lately as we have beem pretty busy but getting back to it now. Gonna try some things and see how it goes.
    Aug 2008
    406
    In your first post there are two pics the one on the right . The settings page thats where the problem is .If I remember I will take a pic of mine . I made a program to cut taper and had some problems . If I remember when the Program plan was the the same as thickness i got en error .
    Aug 2008
    406
ID:	485794Click image for larger version.
ID:	485796 This cuts taper .
    May 2010
    61
    Thanks! I'll try setting mine to your settings and see what I get. Question, on your upper guide setting, where did you get that figure? Or I guess how did you calculate it? As I can see it the lower one shouldn't ever change as long as the guides are the same. my machine doesn't have the DRO just the vernier scale for the Z.
    Mar 2016
    325
    There is a part for it in manual. Generally U should set the. Value from the scale and add some little distances from the guides data. But having a guides data is not obvious (i've bought new guides some time ago nad there were no data, and it's possible to lose it sometimes too) so U can calculate that from practical cut. When U cut some known part U should measure it and calculate precisely set distances using trigonometry.
    May 2010
    61
    I have tried that with a CAD program and didn't get it to do anything but give me an error. however, since I have it cutting them again I'll try it one more time. I have the data from the guide so in theory I should be able to add that to what the scale has and get it close. I'll try it again and see. BTW, did you get yours figured out? I never could get ahold of the guy to tell me exactly how to measure what you were asking for. And I'm not real good at electrical.
    Mar 2016
    325
    No problem. I'm still fighting. But unfortunatelly my electronic friend was unable to help (could said that a little earlier :/) so i sent some suspicious parts to relevant service. Hope my wallet can handle that
  1. Replies: 5
    Last Post: 04-20-2019, 02:31 PM
  2. Fanuc robocut not cutting square
    By Meintjes in forum EDM Discussion General Topics
    Last Post: 11-22-2018, 01:05 PM
  3. Fanuc Wire W1 Taper Cutting
    By Krispee in forum EDM Discussion General Topics
    Last Post: 09-17-2018, 02:04 PM
  4. EDM Cutting Conditions For FANUC Robocut (alpha)-OC and (alpha)-OiA
    By aaronell in forum EDM Discussion General Topics
    Last Post: 11-02-2015, 07:01 PM
