586,094 active members*
3,758 visitors online*
Login Register
SolidCAM Forum
Leadshine > Can ACS606 servo drive use +-10v analogue signals?
Results 1 to 3 of 3
    Hi there
    Looking to replace a z axis motor and drive, but my motion controller (csmio IP/A) only outputs +-10v, because i wanted to keep the X & Y axis brushed dc servo motors and drives.
    Really struggling to figure out which servo drives actually accept analogue +-10v signals, as the descriptions are often very vague
    I was looking to buy this kit instead of messing around trying to get the old brushed dc motor and 24v encoder to work with a new drive,
    its a ACS606 servo drive and a BLM57180 motor
    https://www.ebay.co.uk/itm/314001264...kAAOSww7VhpzBo
    was also considering ac servo motors but cant find any with a small enough shaft.
    cheers for any help
    fin
    Dec 2003
    24221
    Re: Can ACS606 servo drive use +-10v analogue signals?
    Isn't the ACS606 a pulse/dir input?
    Is the loop closed back to the drive or the CNC controller? If the Latter, then any of the A-M-C analogue input drives should work, their are also other manuf of Torque mode drives.
    The BLM57180 motor is BLDC.
    Albert E.
    15362
    Quote Originally Posted by finyuk2005 View Post
    Hi there
    cheers for any help
    fin
    Dc brushed motors like this are not a good choice
    Cosmo do have a Step/Dir control but yours is not, that is not a great replacement drive and motor is Step/Dir only, you could find an older Yaskawa Servo Drive and motors SGD-04AS is +/-10v you have to use a matching motor with this drive also, DMM also have what you could use also https://dmm-tech.com/
    Mactec54
  1. YAPSC:10V : The glue between Step/dir and +/-10V servo amp
    By MaX-MoD in forum Open Source Controller Boards
    Last Post: 04-27-2023, 09:59 PM
  2. Acorn analog 10v & AC Servo drive RPM questions
    By hax0red in forum Servo Motors / Drives
    Last Post: 08-25-2021, 11:07 PM
  3. Configuring ST-V2 BOB for 0-10V analogue control Mach3
    By SharpShooterSer in forum Spindles / VFD
    Last Post: 03-27-2018, 03:44 PM
  4. Can MACH generate +/- 10V to control SERVO spindle Drive?
    By cjchands in forum Mach Software (ArtSoft software)
    Last Post: 07-23-2007, 03:58 AM
  5. How to drive Analog Servo Input +/- 10V
    By gurvy in forum CNC Machine Related Electronics
    Last Post: 05-31-2007, 05:31 AM
