Hi, i am new to CNC machining and so far i have been learning by trial and error working mainly with MDF. however i need to machine some thin 1mm aluminum i want to cut some shapes out of it . my ultimate goal is to find out what speeds and feed rate to use but also at the same time some help to understand the tool's datasheet so i can calculate this for the future.
the machine is an Itech 6090 generic Chinese made but a bit studier than the cheap ones on ebay. the tool i need to use id a Dormer 3mm end mill 4 flutes here is its datasheet https://docs.rs-online.com/9913/0900766b80d1c5d1.pdf
when ever i read about how to calculate RPM and feed rate it says look up the datasheet for chip load and SFM neither of which i can see in this datasheet.
can anyone help me work out what i should be using for RPM and feed rates?
