586,103 active members*
3,437 visitors online*
Login Register
SolidCAM Forum
Spindles / VFD > Need Help Fuling BD612 VFD and open-loop SVC
    Mar 2024
    Hello,
    I am new , from France and I try to explain my problem:
    My Spindle 6.0Kw run normaly when I use V/F control but dont want to turn when I choose Open-loop .
    I thing something is wrong in the parameter also I search for a complet file with the parameters.
    I join a file with my parameters when I try to make run and a link with the spindle speed KO.
    https://www.youtube.com/shorts/GmxI05sYVkU
    Thank you at all for your help.
    Michel
    Mar 2024
    Re: Need Help Fuling BD612 VFD and open-loop SVC
    Hello,
    Nobody have tryed this configuration?
    If you have with another inverter I could also compare with mine.
    If youhave some idle time to answer me .....
    Cdlt*Michel
