Yes, tapered endmills can be the solution if the mold has simple contours. Internal corners can be problematic if the designer is not aware of the limitations of a tapered tool, because a tapered tool lends itself to cutting corners with a variable radius.
Other times, you may have to use ballnose endmills and simulate the taper by going round and round with very shallow changes in depth between passes.
