586,094 active members*
4,110 visitors online*
Login Register
TDM Systems Forum
Digital. Experienced. Powerful. - 100% Tool Management
Uncategorised CAD Discussion > VIACAD: Text Lines Help
    In ViaCAD, when I convert text to lines or curves to add lines to connect the islands then start trimming it completly screws up the letter. What am I doing wrong?
    Attached Thumbnails Attached Thumbnails Picture 1.png   Picture 2.png   Picture 3.png
    Mar 2004
    413
    Quote Originally Posted by NorthridgeFab View Post
    I assume your goal is to use your two new vertical lines to create a gap of sorts in the letter B. To do this, you need to use the "Segment" tools found in the trim flyout. I believe "Segment to Curve" is the default tool in the flyout and if you select that, you get an additional toolbar that pops up on the screen. In THAT toolbar, probably the simplest thing you can do is use the "Segment at Location" tool and just click on the horizontal lines of the islands of the B BETWEEN your two vertical lines. This will BREAK the islands into a left and right section. Then you can use the traditional corner trim to finish up.
    Essentially, the "Segment at Location" "cuts" a line or entity.
    Hope that helps !
    Chris L
  1. ViaCad 2D/3D v8 for Mac
    By JReed3 in forum Uncategorised CAD Discussion
    Last Post: 01-04-2012, 05:30 AM
  2. Replies: 1
    Last Post: 08-11-2010, 01:59 PM
  3. Multiple lines of text
    By phatjap in forum Mach Wizards, Macros, & Addons
    Last Post: 05-06-2010, 08:34 PM
  4. ViaCAD 3D V6
    By Herbertkabi in forum Uncategorised CAD Discussion
    Last Post: 08-04-2009, 06:22 AM
  5. Has anyone tried ViaCAD 2D/3D
    By athomas in forum Uncategorised CAM Discussion
    Last Post: 05-23-2009, 02:55 PM
