586,080 active members*
3,614 visitors online*
Login Register
TDM Systems Forum
Digital. Experienced. Powerful. - 100% Tool Management
Bosch Rexroth > Matec 30 HV Bosch OSA3
Results 1 to 6 of 6
    Oct 2005
    659
    Hello people
    Is anybody familiar with Matec 30 HV Bosch OSA3?
    I have to write a PP for this machine. The machine has two separate workflows.
    It has AB axis on the left and BC axis on the right side as swivel axes.
    What about swivel cycles? Does the OAS4 controller have anything like this?
    If it has, what do they look like?
    I haven’t managed to found a programming instruction. Does anybody know a link?
    Greetings
    Sit22
    <span style='color:blue'>Mit freundlichen Gr
    Sep 2003
    120
    Hello people
    Greetings
    Sit22
    Hello Sit22
    I’ve got a pdf… “Operating manual Matec 30 L / S / LD / SD / HV”
    Maybe it would help!
    Greetings
    Debugging? Klingonen debuggen nicht. <br>Unsere Software ist nicht dazu gedacht, <br>die Schwachen zu verhätscheln.
    Mar 2008
    5
    Why don't’ you contact the manufacturer?
    Quote Originally Posted by Sit22 View Post
    Hello people
    Greetings
    Sit22
    Hello,
    Can you send me please a pdf with informations about Matec 30 L ?
    Feb 2017
    Hello,
    I have a machine Matec 30 HV with Bosch Rexroth cnc controlled.
    I want programming by the parameters but I dont know who to write.
    I write for example @200=10 and give some error for syntax. I try with #201=10 and the same error from syntax.
    Thank you
