586,082 active members*
3,530 visitors online*
Login Register
TDM Systems Forum
Digital. Experienced. Powerful. - 100% Tool Management
Bosch Rexroth > Bosch CC200
Thread: Bosch CC200
Results 1 to 3 of 3
    Jan 2008
    6
    Does anybody know this error message?
    NC-error 2670
    SPS time out
    Kind regards
    Axel
    I have a similar problem with the Bosch CC 300 M Wanderer. Does anybody know the solution???
    Quote Originally Posted by alanser View Post
    NC-error 2670
    SPS time out
    Kind regards
    Axel
    Hey Alex, NC error 2670 (PC TIME BARRIER) Could be different things....What machine are you using with this controller?
    Causes may be:
    1. Check if SPS is running
    2. Is switch Edit/Monitor on RAM Board in Monitor position?
    3. Battery power loss could also be the case.. Check all your batteries
    4. Did you check your connection cables? between NC and SPS?
    5. Is the Ausg. Sperren (Clear Output) switch on the ZE Board in the UP position?
    Let me know if after this you still have the problem..
    Regards..
    Mak
