586,113 active members*
3,724 visitors online*
Login Register
TDM Systems Forum
Digital. Experienced. Powerful. - 100% Tool Management
Haas Mills > haas tm1p 2007 spindle air leak repair help
Results 1 to 3 of 3
    May 2006
    107
    hi
    i have a haas tm1p with 10tool atc
    the machine is leaking alot of air way more than normal from the top of the spindle unit, under the pully area. it leaks more air from the top than the bottom of the spindle unit, this is the air pure for spindle ,
    this is not the tool air release blow air cleaning air leaking ..
    so i assume there are some seals in side or are they o-rings that need replacing.
    has any one done this on a tm1?
    if so can any one share what the seal type , size etc is that is needed so i can order the seals ready?
    haas was no use they just want to sell a new spindle unit only
    thanks
    Quote Originally Posted by Craftman805 View Post
    Our 2009 TM1P was leaking air near the spindle. It used to blow soft air out to the bottom of the spindle normally but noticed a lot more air leaks. Took the cover off and found the airline had come off the spindle. Broken off belt pieces snapped off the airline from the spindle.
  1. Water cooled Chinese Spindle - air leak
    By analogman in forum Spindles / VFD
    Last Post: 06-23-2016, 02:08 PM
  2. Replies: 4
    Last Post: 10-04-2013, 12:35 AM
  3. Conquest 42 - Air leak heard from the spindle
    By MorueM in forum Hardinge Lathes
    Last Post: 09-13-2012, 04:05 AM
  4. Spindle Air Leak on Haas VF-OE
    By matt@wmw in forum Haas Mills
    Last Post: 01-20-2011, 03:34 PM
  5. tm1p spindle air leak
    By timmydabull in forum Haas Mills
    Last Post: 08-15-2009, 07:40 AM
