Hi Guys.
I am having a problem when tapping on a 2-axis lathe, X and Z. As the mirror rotates, the Z axis enters the part exactly as long as the tooth. While the mirror should stop immediately and go back to the z axis, the mirror continues to rotate in the same direction at the same tapping speed for another 4-5 seconds. Meanwhile, the Z axis waits without moving. Meanwhile, when I look at the spindle monitor, I see value in Motor Speed, but I do not see value in Spindle Speed. After 4 5 seconds
The spindle starts to rotate in the other direction and the Z axis starts to move back. I use position coder connected to spindle. Has anyone had a problem like this before?
