586,108 active members*
3,293 visitors online*
Login Register
TDM Systems Forum
Digital. Experienced. Powerful. - 100% Tool Management
Haas Mills > disassemble Haas 5C indexer
Results 1 to 9 of 9
    Aug 2006
    18
    Have indexer disassembled (2004 model) except for center housing that holds the worm screw, and brass block. Seems to have a dowel pin (only one?) that prevents the center housing from being removed, the 5 allen screws are removed. Also, does the worm screw/bearing and input shaft get pressed out?
    From which direction? A diagram would be great if available. thanks for any input.
    4826
    I'm looking at a parts list/assembly drawing for an older 5C.
    I don't see any real tricks although it is difficult to see in great detail. By the term , "brass block", do you mean the worm gear?
    In my guesstimation, I think you'll have to remove the worm first. If you've got the motor off, and the coupling off, that should clear all obstruction on that end of the worm shaft. Then you can perhaps just pull the shaft out the other side, causing the spindle to roll as you do so.
    Then, you might be able to take the spindle out and have the whole mess fall apart on you
    Aug 2006
    18
    Disassemble Haas 5C indexer
    Removed dowel pin with a 6/32" screw and a puller. The worm and bearing/shaft don't want to tap out either way. (setscrew removed, moderate pressure applied. ) Don't want to damage anything!
    Dec 2005
    183
    Was this issue ever resolved? I'm up against the same problem.
    Jun 2009
    135
    It is a good possibility that the dowel pin is a pivot to adjust the worm gear play in conjuction with jacking screws that have to be loosened. Also on the front is there degree wheel (1.5' diameter?), if so remove it as there may be a bearing nut behind it.
    Dec 2005
    183
    The dowel pin secures the worm gear outer ring to the indexer body. You have to remove the dowel pin to slide the housing out the side.
    When you remove the degree wheel, all you see is the end of the worm screw and a bearing. I also removed the stepper motor from the other side. There is a coupler from the motor to the worm shaft but no screws of any kind.
    It would seem like you need to clamp the large ring in place and rotate the screw to drive it out the end. Obviously turning the screw just turn the gear. However, it's a little hard to turn the screw since there is nothing to hold onto.
    Also, mine was filled with grease but I know the new servo units take oil, any thoughts on that one?
    May 2008
    5
    HuFlung Dung, Could you share those drawings?, I just bought an old haas 5c indexer (the one with stepper motor), it was working fine, but now is look that something is worn or loose, the motor spins but the indexer don't, I need to know how to disassembly it, I don´t want to mess it, thanks
    Aug 2010
    579
    Here is an excerpt from a rotary operators manual from 2001, let me know if you need a different version.
    Attached Files Attached Files
    Ken Foulks
    Re: disassemble Haas 5C indexer
    Quote Originally Posted by KenFoulks View Post
    Ken, do you have an exploded view for an ancient 5C Indexer with stepper motor, serial no 193888?
    It is nearly mint condition but could do with some adjustments now it's run in!!!!
  1. Haas S5C indexer
    By Petergun in forum Haas Mills
    Last Post: 06-11-2013, 04:20 AM
  2. Haas 5c indexer help!
    By cmacclel in forum Haas Mills
    Last Post: 04-11-2013, 11:46 AM
  3. haas indexer
    By Jfrahm in forum Fanuc
    Last Post: 12-15-2010, 09:13 PM
  4. Haas Indexer
    By binzer in forum Haas Mills
    Last Post: 12-16-2009, 03:10 AM
  5. Haas VF1 & 5C Indexer
    By lovell110 in forum Haas Mills
    Last Post: 12-08-2007, 06:39 AM
