I run VC 8 on a 2 core 5th or 6th generation old Systemax I bought refurbuished with XP 32 bit from Tiger direct and it wokrs ok. I have issue onlys when I am working with complex 3D stuff with lots of modifications in the history. Its seems to me v7 was about the same. Stable with simple stuff, and less stable the more work you had done. Autosave is your friend. Another thing I found that helped is when I am sure I am at a solid spot in development of a piece of work I stop and save it. Then I close the file and the program and reopen it. I lose the history, but it seems to be stable again for quite a long time. I do mostly 3D in ViaCad with 2D being mostly supplemental to 3D. For straight simple 2D jobs I usually just do them in my CAM software.
I ran V7 on the machine with the onboard video card for a while, but I admit that now I am using a PCI-Express Nvidia dual head card. I did that to free up some memory though. The biggest problem though is that a 32bit OS can not access all the memory I could put on the motherboard.
Anyway, the dual head card is awesome. I often have ViaCad open on one monitor and CamBam open on the other. For complex 3D that will cause memory problems, but for simple stuff its very handy. I also often have a refference document, calculator, or web page open on one screen and CAD or CAM open on the other. My big complaint is that the tool bars don't move when I move ViaCad from one monitor to the other.
Bob La Londe
http://www.YumaBassMan.com
