588,487 active members*
5,845 visitors online*
Login Register
VDW - Banner
VDW Forum
Jewelry Design Software > New to CNC milling (Jewellery)
Results 1 to 14 of 14
    Exclamation New to CNC milling (Jewellery)
    Dear All,
    I came to know about cnc milling recently and I am HIGHLY interested in this field. It was pure coincidence that lead me to the world of cnc through one of my colleges. She guided me toward miramill.com
    I was interested in their 5-axis mill until I came to know the price tag. Therefore, I search for cnc milling communities help, seeking their advice.
    Hence, I am looking for a machine that will produce me the wax models as per the photos below:
    http://s8.postimg.org/hml68w5jp/image.jpg
    http://s10.postimg.org/e7zvce421/nef..._wax_stock.jpg
    http://s30.postimg.org/mah8j0i4h/023.jpg
    http://s17.postimg.org/76r40xk1r/d34...8aeb98dbb2.jpg
    Additionally, I am looking for a machine that is compatible with jewellery designing software Rhinoceros 3D
    Best regards,
    Apr 2004
    5760
    Re: New to CNC milling (Jewellery)
    It looks like those rings were done with a 5-axis machine. The Nefertiti pendant could have been done with a 4-axis one, though. Rhino is a CAD program; no mill will directly handle the files it produces. You'll need some kind of CAM program to generate toolpaths from the CAD files, taking into account the tools and other parameters, and generate a G-code file the mill software can execute. RhinoCAM from Mecsoft is a good choice for that, since it plugs into the Rhino workspace, but there are others as well.
    Andrew Werby
    Website
    Thanks Awerby.
    Can you think of any machines you recommend for such job? 5 axis?
    Additionally, does operating on a CAM software require a professional for such a job? or is it something I can learn?
    Regards,
    Apr 2004
    5760
    I don't know of any inexpensive 5-axis mills that are worth buying, sorry. But CAM software is not that difficult to operate; it's easier than learning to use a CAD modeler. If highly detailed patterns with lots of undercuts like that are what you really want to do, you might look into 3D printing rather than CNC milling; that additive technology's come a long way, and isn't as expensive as it used to be.
    Andrew Werby
    Website
    Hi - well I actually own a 3D printer, and it has limitations, that is why I want to switch to CNC milling.
    Can you please recommend 3 cnc mills?
    Regards,
    Apr 2004
    5760
    Quote Originally Posted by munzerxo View Post
    [There's a wide variation in 3D printers, and the common hot plastic extrusion type doesn't make surfaces fine enough for jewelry. There are others, though, that work much better for that: either hot-wax deposition type printers (eg: Solidscape) or photo-catylyzed resin printers (B9 Creator) produce models with good surface detail in materials that can burn out in a "lost-wax" casting process.]
    Regards,
    [Certainly; take a look at mills by Taig, Sherline, and ACT; there's more information about them on my website.]
    basically from the preliminary research that I have conducted, CAM programs generates the footpath of the milling machines. Is
    there an automated way, where i can feed the STL/design of the jewelry I want printed on the wax, and the footpath is generated automatically?
    [Take a look at DeskProto; it's a fairly simple CAM program well-suited to making artistic sorts of parts. You import the STL file, and make certain decisions, like what tool to use, how much material to remove at a time, how fast you want to feed, etc. and it produces a toolpath and then post-processes it to suit the machine you're running it on.]
    Andrew Werby
    Website
    Hi - basically from the preliminary research that I have conducted, CAM programs generates the footpath of the milling machines. Is there an automated way, where i can feed the STL/design of the jewelry I want printed on the wax, and the footpath is generated automatically?
    Jan 2007
    1795
    rhino very great for modeling..
    they have already a plugin, clayoo what makes even simpler modeling..
    for machines, very much jewelrymaker use the neogroup machines..
    they have 5 axis, what works actually as a 3 axis added a trunnion table
    if your budget let you invest you can step up for a datron, or a kern evo..
    these two machines capable to mill polished surface, and simply skip the casting process.. no wax no melting no casting..
    you can mill one single coin, or mill the polished coinstamp..
    kern evo used by watchmakers..
    3d printers.. yes solidscape had a great time, til different copyrights were prohibiting the lasersintering..
    since those out of the term, new printers came up for 1/8th price of a solidscape price.. even these new printers are faster..
    additionally you don't need anymore worrying on ""braces""..
    these new printers are printing ""backward"" and printed stuff hanging down, vs old method build on table..
    Full Spectrum Laser
    this can create same than solidscape..
    Oct 2010
    1189
    Hi did you Look at dls printing ? Using resign? Milling wise i think ID use a good Router to Start and a 4th axis i own an heiz 400T and an roundino to Start with in your case you need madcam or rhinocam to do the milling.
    And Then later i would Upgrade to an trunnion table but your learning curve will be quite steep thomas
    Gesendet von meinem SM-N9005 mit Tapatalk
    Quote Originally Posted by Tkamsker View Post
    Hi - Thanks for your recommendation. However, I do not have time to setup a 4 axis and then add trunnion and learn footsetps etc...
    I need a 5 axis machine, with an automated CAM software to mill the jewellery I need. And recommendations guys?
    Regards,
    Apr 2004
    5760
    You say you need a good 5 axis mill, but you don't want to pay for one. You say you don't have time to set up an alternative machine, and you want an "automated" CAM software solution - presumably with some robot at the controls - but I doubt you'll want to pay for that either. It sounds like you're either going to have to come up with more money or more time...
    Andrew Werby
    Website
    Quote Originally Posted by awerby View Post
    Hi - you are very true, what I am looking for is entry level 5 axis mill and automated CAM software, that is why i am reaching for your recommendation for the cheapest deal I can get.
    Can you recommend 3 machines and 3 CAM automatic CAM softwares?
    regards,
    Oct 2010
    1189
    munzerxo There is no automatic in CAM Software 3d is easy but to do 4 an 5th axis you will have a learning courve
    And you will find out in your case that the machine is much cheaper than the cam software you need to get fast and good results
    but lets see how your tourney turns out
    i am interested because i do now 5th axis for our machines
    Jan 2007
    1795
    check this
    https://www.kickstarter.com/projects.../posts/1354015
    this would be for your budget and 5 axis..
  1. Looking for a CNC-machine for titanium jewellery
    By herrMrtn in forum Want To Buy...Need help!
    Last Post: 08-27-2010, 10:03 PM
  2. Bear Jewellery Box :)
    By Khalid in forum CNC Wood Router Project Log
    Last Post: 03-18-2010, 12:13 PM
  3. looking for jewellery engraving machine
    By mielsita in forum DIY CNC Router Table Machines
    Last Post: 05-27-2008, 04:53 PM
  4. Pro Jewellery Casting Company
    By ChuckInCR in forum Casting Metals
    Last Post: 04-05-2008, 12:04 AM
  5. Making exotic hardwood jewellery
    By Synaptic in forum CNC Machining Centers
    Last Post: 02-14-2007, 11:30 AM
VDW - Skyscraper
