588,513 active members*
4,719 visitors online*
Login Register
VDW - Banner
VDW Forum
Mastercam > Adding solid body
Results 1 to 2 of 2
    Feb 2012
    40
    Adding solid body
    Hello,
    I am trying to add some solid to body to existing solid body.
    In the picture below, I need to add some solid to be like red outline(doesn't have to be exact size) so that the solid material would support the spoke.
    How do I achieve this?
    Would anyone can tell me how to do this?
    Thank you in advance,
    Ken
    Attached Files Attached Files
    Dec 2008
    3142
    Try doing a "solid chamfer"
    - note....it has different options available for standard, 2 lengths, 1 length + angle variants of chamfers, so read the prompts as you go
    or
    create a solid wedge of what you want, copy/mirror/rotate to all places you need it,
    - then do a" booleen add " to make it into a singular solid
    ----first solid picked is the parent shape, additional solids are the parts added
  1. les paul solid body
    By stukent in forum Musical Instrument Design and Construction
    Last Post: 03-13-2020, 09:04 PM
  2. Slicing a solid body in increments in xy plane
    By fastfrank in forum Mastercam
    Last Post: 11-20-2010, 09:59 AM
  3. trim solid body
    By encarlisle in forum UG NX
    Last Post: 03-20-2009, 04:43 AM
  4. Ibanez jem 77 solid body
    By rockerfx in forum Musical Instrument Design and Construction
    Last Post: 07-10-2008, 12:07 PM
  5. Solid Extrude Cut Body
    By Mastercam User in forum Mastercam
    Last Post: 12-01-2007, 05:48 PM
VDW - Skyscraper
