588,484 active members*
5,081 visitors online*
Login Register
VDW - Banner
VDW Forum
Post Processors for MC > OSP Okuma POST PROCESSOR MASTERCAM 2018
Results 1 to 16 of 16
    Jul 2018
    Someone has the post processor OSP P300M OKUMA to MasterCam 2018 to share?
    Thanks in advance
    Mar 2015
    21
    Re: OSP Okuma POST PROCESSOR MASTERCAM 2018
    I know this is a kinda of a late reply but I hope it helps someone.
    Only Okuma post I have.
    Sep 2020
    Hello TampaCNC, thank you for the okuma post files !!! Did you tested some of this post processor?
    Mar 2015
    21
    works fine for me.
    Oct 2018
    101
    hey do you have post for lathe as well ?OSP? U100L or OSP7000?
    Sep 2021
    Do you have post processor for Okuma OSP P300LA to mastercam? thank you
    Mar 2015
    21
    Quote Originally Posted by LODI View Post
    I'll dig and see what I have.
    Jun 2019
    17
    Quote Originally Posted by TampaCNC View Post
    Hello TampaCNC. I’m looking for the vertical 3ax OKUMA OSP200 post processor. Do you have something to share? You would definitely give me a huge favour!
    Mar 2015
    21
    Quote Originally Posted by MicMeadow View Post
    Give it a try.
    Jun 2019
    17
    Give it a try.
    First of all thanks a lot!!! But unfortunately they are made for a 2018 version of MasterCam. I’m using the X9. The first bundle you’ve posted on this thread works fine but it’s for a simultaneous 4 axis machine and im running a normal 3ax. Thank you for your help anyway! Just in case, if you have something else to try do not hesitate to post it!
    Thank you!
    M.
    Inviato dal mio iPhone utilizzando Tapatalk
    Mar 2015
    21
    Thank you!
    M.
    Edit your Okuma post file with notepad (you have to right click the post and select edit with and choose notepad as default.) and change the 1 to 0 to disable the 4th axis. Example is the generic MPFAN
    Jun 2019
    17
    Perfect!
    Thank you!!!!!
    Mar 2015
    21
    No problem. I know it can be frustrating not knowing what to do.
    Jan 2023
    4
    Hello, maybe you have already found a post for Okuma P300LA? If so, could you share it? Thank you
    [email protected]
    Feb 2023
    hola necesito post procesador para mastercam a nivel de torno y fresa para okuma p300 O P200 muchas gracias
    [email protected]
    Hello TampaCNC. I’m looking for the lathe OKUMA LB 300 , OSP U100l post processor. Do you have something to share? You would definitely give me a huge favou1
    thanks man
VDW - Skyscraper
