Hi!
I got this fault codes on our Robofil 440CC
1174 UAL Power circuit
1179 HPF in protection
1182 HPF
Does anyone have any idea what the issue could be?
Best regards Almberg
Hi!
1182 HPF
Hello Almberg,
Did you find the reason for the fault codes ?
Graeme
did you find a solution for your error 1174 ? E1174 ? i have been fighting with that error on my 2007 240cc and need some help
- - - Updated - - -
did you get your error 1174 fixed? do you have a solution?
could really use some help on error 1174 guys thanks
any solution to error 1174?
I had the same error. I check the back plane of the Generator and on the back found 2 electrolytic capacitors. I have been same problem, with a oscilloscope in the output of generator had 32 Khz and was coming down and appear the error again. I was checking power supplies and other. I remove the power transfomer: INPUT: 440VAC, 3phases OUTPUT: 220 VAC, 3 phases and 2 voltages of 60 VAC for each electrode. I bias with 440VAC put resistor load for 30 AMPS in 60VAC the voltage was down to 4 and 6 VAC. The transformer is bad.
Apppear error 1182, broke the wire, etc. I bought the transfomer (like 3,500 USD in Charmille) I change it and the machine is running very fine wit a good spark plug. GOOD LUCK...
