588,002 active members*
2,946 visitors online*
Login Register
VDW - Banner
VDW Forum
DNC Problems and Solutions > Mori - Fanuc communication error
Results 1 to 2 of 2
    I have a Mori NV5000 with the MSG-501 ( Fanuc 18 ? ) control. The M-Card will receive a program, but when I send the same program back, it only receives about 10 lines of code, then just says error. I switched to RS-232 and have the same problem. What parameter could be causine this ?
    Thanks !
    Walt Owens
    Re: Mori - Fanuc communication error
    hi I ,Did you manage to repair the fault, and how can the program be loaded using rs232 in that control
    thank you
  1. Replies: 0
    Last Post: 02-28-2019, 04:46 PM
  2. Mori Seiki Fanuc O-T Error EX357
    By hrhoward in forum Mori Seiki lathes
    Last Post: 06-11-2014, 04:30 AM
  3. MORI SEIKI MV-40B FANUC OC EX0625 ERROR CODE
    By cebjr79 in forum Mori Seiki Mills
    Last Post: 06-28-2012, 05:08 PM
  4. Mori Seiki Fanuc 3T error
    By haitd in forum Fanuc
    Last Post: 03-08-2012, 08:51 PM
  5. Help... Fanuc ZeroT Communication error
    By Surfnerv89 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-14-2005, 09:13 PM
VDW - Skyscraper
