I have a strange problem. I've been using MadCam 5 beta and have now downloaded and upgraded to the release version of 5X. For the first time, I'm trying to use it on my 4 axis Mach 3 driven router but I'm having problems. I setup my machine with the A axis parallel to the Y axis (0,1,0) and set my axis of revolution to origin 0,0,0 direction 0,1,0. Everything looks right, the toolpaths look right by eye but in the simulator and in the post processed code, it's actually running the bit through the model and cutting from the inside of the cylinder containing the stock model.
I thought I remembered in 4.3 that there was a cut inside option or something like that and that you could specifically pick the line for your spindle axis but I don't see that in 5.0 Am I missing something?
Thanks in advance for any help.
