The pin inside my 1100 spindle has always been a bit short, barely but adequately engaging the R8 collet. Last week, my PDB was acting funny- it wasn't releasing far enough. Tools that were an easy in/out earlier were almost press fits on the open collet. A little checking showed that the pin was still present, but had been worn to a dished shape and no longer engaged the collet.
Tormach was helpful as usual, but the answer wasn't much fun: the only way to change the pin is to completely disassemble the spindle, as the pin is located under the bottom pair of bearings. This is a summary of learnings from that adventure.
Removing the cartridge is straightforward.Remove PDB. Position the head about 2/3 up from the table. Remove the jam nut from the pulley, remove the pulley from the spindle. Pulley can't be completely removed without taking the motor out; don't bother. Remove 6 bolts holding the cartridge in place and remove it from underneath; it'll clear the pulley.
Mark the position of the spindle nut carefully (needed to restore the preload at reassembly). If possible, measure the height of the nut from the bottom of the spindle (it's about 10 inches up), opposite the screw on the jam nut, as a second check on preload position for the nut.
Remove the nut.
At this point, one has a couple of options. Tormach recommends that one press out the spindle, bracing the cartridge housing via the bolt flange. That worked, but while the top bearings remained in the cartridge, the bottom bearings came out with the spindle. The bottom spindle spacer is designed to be used to remove the bottom bearings; it bears on the inner race of the bearings. The problem with the Tormach procedure is that the bottom bearings are very likely to come out of the cartridge housing with the spindle; the advantage is that there is less pressure on the bottom spacer, and the flange is very strong.
However, one must still remove the bottom bearings. The pin is roughly at the center of the bearing pair.
I was concerned that the spacer (part #90 in my drawing) was fairly thin and might break; Tormach assured me that it was designed to be used to press the bearings off. I made a 4" diameter ring 2" high with a 2.05 hole (which will pass the spindle nose freely) and used that to bear on the spacer. I also obtained some dry ice, and filled the spindle with that -a piece of packing tape held the ice in place- just prior to pressing the bottom bearings off. A minute or so was enough to cool the spindle while the bearings stayed relatively warm. They came off easily. Be careful to maintain and mark the orientation of the bearings; these are deep groove angular bearings and fit only one way. I maintained the order, too.
In retrospect, I think a better approach to removing the spindle would be to pack the entire spindle with dry ice and press against the spacer in the first place, with a ring as described above bearing on the bottom spacer. I suspect the spindle would easily pop out leaving all 4 bearings in the cartridge housing. Life would be much simpler in that case, as long as the spindle reinstallation didn't require too much pressure.
With the spindle free of bearings, one can (barely) locate the pressed in locating pin. Mine was ground very smoothly level with the bearing surface, and was rather hard to see. The pin is 0.140 diameter; mine was 0.326 long, and should have been about 0.375. A drift punch will remove the pin, which isn't long enough to get caught in the spindle bore.
The remaining problem is what to use as a replacement. Tormach does not stock pins, and the pin is not a standard dowel size (either metric or inch). My solution was to use a piece of a #28 drill (0.1405), ground to length. The original pin was easily filed, despite Tormach's comment that it was a hardened dowel (I think that was speculation, not fact). I installed the pin with the collet in the spindle, using a 0.006 shim in the collet groove to make sure the pin didn't bottom on the groove. Tormach recommends using Loctite 609 or similar (eg, 648) on the pin; I did not, as it seemed to be a tight press fit with no wear on the hole.
Reassembly is straightforward. Reinstall the lower bearings (watch the orientation) if they came out with the spindle, using dry ice or a cold soak to get the spindle as small as possible, pressing the bearings on by pushing on the inner race. Put spindle in cartridge housing, reinstall the preload nut. Tormach recommends tightening the nut to 1 full turn less than the original installation (in my case, that was with two threads showing above the nut at the point where the jam screw is located), Correct preload is obtained when the nut is "tight" and the bearings don't exceed 155F. See Tormach bulletin SB0024_Spindle_Bearings_0914B for the detailed procedure. My original bearings ran at 70F even after hours of running; I plan to recheck the reinstallation a few times over the next week or so.
Reinstall cartridge, pulley, PDB, etc. Hope the new pin lasts a bit longer.
Thanks to Tormach for helpful advice through the entire process.
