588,484 active members*
4,693 visitors online*
Login Register
VDW - Banner
VDW Forum
Machines running Mach Software > mach3 Digital Read Out Jumping/Bouncing
    Aug 2019
    Question mach3 Digital Read Out Jumping/Bouncing
    So ive just changed over my break out board for something that supported slave with additional axis and im have everything working moving etc hooked up ready to go.
    But my digital readouts are bouncing / flickering as such when drivers and machine are at idle/ not moving.
    This is obviously causing issues with ref homering, as the change in values is locking the endstops as it thinks machine has past the limit.
    Is this a grounding issue?
    Regards
    Jun 2005
    1732
    Re: mach3 Digital Read Out Jumping/Bouncing
    Sounds like an EMI noise issue. Does it do it worse when the spindle is running?
  1. question about Digital read outs
    By mamech in forum Uncategorised MetalWorking Machines
    Last Post: 04-24-2016, 01:58 PM
  2. x2 mill. digital read outs jumping around
    By brendan_h in forum Benchtop Machines
    Last Post: 03-23-2014, 12:16 AM
  3. DIY DRO (digital read out)
    By rlwoodjr in forum Open Source Controller Boards
    Last Post: 01-16-2012, 05:29 AM
  4. Laser triangulation for digital read out???
    By jduke in forum Benchtop Machines
    Last Post: 04-11-2011, 09:11 PM
  5. A Digital read out ? on our BenchMills
    By Arich0908 in forum Benchtop Machines
    Last Post: 04-28-2010, 05:18 PM
VDW - Skyscraper
