How do you cut fabric leather and some other related flexible materials? What is the best cutter for it? I bet there are a lot of customers who say it's a laser cutting machine. But today I want to introduce a better cutter to you.-------Deveup cnc digital oscillating knife cutting machine.
Deveup digital cutter is equipped with high-speed wheel cutting tool or pneumatic cutting tool, it can do both fast cutting for single layer fabric cutting, and also for multi-layer fabrics cutting. It has automatic nesting software, automatic feeding system and vacuum adsorption system. The vacuum adsorption system draws and fixes the roll-shaped fabrics, and then imports the designed image, such as AI, CorelDraw, CAD, etc. into the machine cutting operating system. The digital cutter automatically cuts on the fabrics based on the designed graphic.
Various cutting tools to meet different material cutting needs:
Deveup CNC digital cutters are mainly for fabric, leather, and composites or other flexible materials cutting. For example, Oxford cloth, Nonwoven Fabric, Chiffon, Prepreg, Neoprene, Synthetic Leather, cowhide, fur, PVC, Foam,Acoustic panel, KT board, car stickers, rubber, sponge, carton, film, fiberglass, fabric, carbon fiber, and other materials. With a variety of tools and pens to meet the cutting needs of different materials, and provide a variety of personalized cutting services.
Problems of artificially cutting fabrics:
1. Some industries have high requirements for cutting precision, manual cutting cannot meet the cutting requirements;
2. The efficiency of manual cutting complex patterns is low, which cannot meet the needs of mass production;
3. The cost of manual cutting is high. If efficiency and precision are required, the number of workers can only be increased, and the cost of workers will be greatly increased.
Problems of laser cutting fabrics:
1. Laser cut fabrics can have yellowed and burnt edges.
2. Smoke and odor problems will occur during laser cutting fabrics.
3. The depth of focus of the laser cutting machine determines that it can't cut multi-layer fabrics well.
4. The Co2 laser tube of the laser cutting machine has a very short life span, which is a few thousand hours. Replacing the laser tube is costly.
5. Laser cutting machine has no vacuum adsorption platform, especially for large format machine, the table flatness is low, the cutting precision is low.
Advantages of Deveup CNC fabrics cutting machine:
1) Deveup digital fabric cutting machine is equipped with high speed circular knife and pneumatic knife or high power vibrating knife, which can cut single-layer fabric or multi-layer fabric at high speed with high efficiency.
2) Deveup digital fabric cutting machine uses sharp and durable tungsten steel blade to cut fabrics, the cutting edge is smooth and neat without burrs or scorching, and the cutting process is smoke-free and odorless.
3) Deveup digital fabric cutting machine is equipped with vacuum adsorption platform, which is very good to ensure the flatness of the fabric, the cutting process of vacuum adsorption automatically start and stop, high cutting accuracy and speed.
4) Deveup digital fabric cutting machine is equipped with automatic feeding platform, so that the machine really realize unattended work.
5) Deveup digital fabric cutting machine is equipped with cutting and automatic nesting software, which can help customers save raw materials.
6) Deveup digital fabric cutting machine has rich-function cutting software, which support many file support such as plt, dxf, AI, dwg, pdf and etc.
