588,385 active members*
5,258 visitors online*
Login Register
VDW - Banner
VDW Forum
Parametric Programing > Threading cycle
    Mar 2006
    153
    Threading cycle
    I have come up with a macro for threading I haven't got to test it yet but thought I would post anyway. As soon as I test it I'll let you know how it works here is the code.
    G65 P9011 X1.840 Z-1.3 F.0869 K4.0 Q0.005 R.125
    X= major diameter of thread
    Z= thread length
    F= lead
    K= number of passes you want to take
    Q= depth of finish pass (diam)
    R= thread hieght (diam)
    Here is the macro. It is used in the same sense as G76(tool,speed, x and y position set before macro call). Once I test it I will put checksum code in it to make sure all required variables have been passed in the G65 call.
    O9011
    #100=[#18-#17] (Calculates depth of cut - finish depth)
    #101=[#100/[#6-1]] (Calculates the depth of each pass)
    #102=0 (Sets counter to 0)
    WHILE [#102 NE [#6-1]] DO 1
    G92 X[#24-#101] Z[#26] F[#9]
    #24=[#24-#101]
    #102=[#102+1]
    END1
    G92 X[#24-#17] Z[#26] F[#9]
    M99
    I will report back once it has been tested.
    Edit due to typo.
    No matter how good you are, there is always someone better!!!
    Mar 2006
    153
    OK its been tested and it works. It makes a NICE!!!! thread. Managment was shocked. I was able to decrease the number of passes and take the spindle speed up to 2800 rpm on black steel tubing. No chatter whatsoever. I only have one problem I passed 4 passes to the macro but it runs 5. I guess I'll have to look over my math again. I'll try and get some pics up of the threads if I can find a camera.
  1. g76 thread cycle
    By warcnc in forum G-Code Programing
    Last Post: 02-03-2013, 11:32 PM
  2. roughing cycle on ot-a
    By iancally in forum Fanuc
    Last Post: 06-03-2008, 03:05 PM
  3. G76 Boring Cycle
    By Gorrell in forum G-Code Programing
    Last Post: 01-25-2007, 10:22 PM
  4. G68 + Rectangle Cycle
    By Shizzlemah in forum Fadal
    Last Post: 01-26-2006, 11:17 PM
  5. How do I set Parameter 592 for G 83 Cycle
    By Farmer in forum G-Code Programing
    Last Post: 11-27-2004, 05:13 AM
VDW - Skyscraper
