ANCA Motion
54
ANCA Motion
54
Flexible Control Systems
ANCA Motion designs and manufacture flexible control systems, specialising in high precision CNC machines. We tailor our hardware and software to a OEMs exacting requirements, providing solutions that give customers a competitive edge. Our continuous support and innovation throughout the life of the product allows us to deliver world class products and service.
Laser & plasma cutting, multi axis machining, automation, profile cutting and customised solutions are just some of the applications we specialise in. Originally starting out in CNC and motors our ability to provide customers with automated control solutions for all industries has seen our product range expand into servo drives, IO, EtherCAT®, user interfaces and software.
Our most recent advancement in technology has come from our LinX® linear motor. Unlike traditional motors the LinX® linear motor helps improve machine life and wear on guide ways or rails. It eliminates the downforce associated with flat motors, due to the zero net attractive forces. The magnetic flux in the new LinX® motor is circular, which comes with it enormous benefits. There is also no back-iron, further reducing cogging and resulting in a smoother motion and superior surface finish.
The LinX® linear motors patent pending thermal barrier is designed to separate and remove heat from the motor, eradicating thermal growth for the machine and making the motor substantially cooler. This has enabled ANCA Motion to remove the need for a dedicated cooling system as the LinX® is able to use the machines current coolant system, improving floor space and reduce system costs.
With no down force and no cogging, and ability of IP69K rating, the LinX® produces truly amazing machine performance is a perfect fit for the automation market and is a superior replacement for ball screw motors in new machine designs looking for greater performance.
ANCA Motion are a designer and manufacturer of flexible control systems, specialising in high precision CNC machines, for over 40 years. Tailoring hardware and software for OEM’s requirements and providing custom solutions in motion control.
Responsible for the content of this press release: ANCA Motion Pty. Ltd.
