BIAX, specialist for industrial deburring solutions, presents four new models of drive motors with flexible shaft for each application area with different performance classes.Go to press info
2023-08-26
Robotic spindles and hand-operated tools with quick-change system from BIAX
BIAX, a specialist in industrial deburring solutions, presents a range of new pneumatic, robotic spindles and hand-held grinders complete with an innovative quick-change system. Go to press info
2023-08-26
THE NEW BIAX T 3-90 S: THE UNIQUE EFFORTLESSNESS OF OIL-FREE GRINDING
BIAX, specialist for industrial deburring solutions, sets new standards in terms of precision, working comfort and environmental protection with the T 3-90 S oil-free grinder.Go to press info
2023-08-26
New Pneumatic Mini Beltsander
Weighing just 500 grams, the HB 3 is a flyweight among belt grinders. At the same time, the machine is surprisingly powerful and quiet. BIAX dispenses with an angular gearbox in this model; the motor sits as a direct drive in the angular head. This saves wear parts and thus increases the service life.Go to press info
2022-02-23
HB 3 - Mini belt sander
HB 3 - Mini belt sander - Small, lightweight and low-maintenance - the new belt sander in mini format.Go to press info
2021-03-30
MB 50 G
BIAX MB 50 G // NEW: Strong power unit developed for tough applications or slight to heavy grinding and milling for tool and mold makersGo to press info
2017-10-16
New mini pneumatic files from BIAX for polishing and fine deburring
BIAX presented two new ergonomic pneumatic files with short stroke lengths at EMO 2017. The machines produce minimal vibration of less than 1.0 m/s2, allowing them to be used intently over a long period of time without risk to health. The files weigh just 260 grams and have a compact design that makes them easy to hold and use, yet they are surprisingly powerful...Go to press info
2016-06-13
BIAX wins gold medal at ITM in Poznan
During the most important metalworking fair in Poland, the ITM, BIAX was awarded with the Gold medal for innovative products. The Jury chose a machine with flexible shaft, the MB 30 E which is indeed best of class.Go to press info
2016-01-19
The art of scraping
Scraping isn’t something that’s taught at vocational colleges and so the knowledge needed for the skills that scraping requires is gradually being lost. As a result, some workshops are attempting to stem the losses but face the problem that there is hardly any relevant training available. Biax recognised the challenge and consequently organised a training event that focused exclusively on...Go to press info
2015-12-07
Easily achieving throughput rates of 150,000 cases
Burrs are removed from around 2,500 transmission and clutch cases every day at IDS Casting Service GmbH in Oggelsbeuren. IDS achieves these throughput rates reliably and smoothly with the help of pneumatic spindles sourced from the Biax company.Go to press info
This website uses cookies
We use cookies to optimize our website for you and to be able to improve it continuously. By clicking the "Accept" button, you expressly agree to the use of cookies. For further information on cookies, please refer to our privacy policy.
