611,340
member accounts
2,261,853
REGISTER LOGIN
LOGIN Register
Suppliers ()
20527 of 20527 products
Machine vice unbekannt Spannweite 150 mm
Welding wire 1.2 mm weight 5 kg Eurotrode M 8820  1.4829
Accessories / spare parts for welding equipment & machines
Hydraulic clamping device Behringer Doppelspannstock HBP 360A
Hydraulic vise Arno Kesel Spannweite 205 mm
Welding wire 1.0 mm weight 15 kg Dratec DT-1.4370  ER 307Si
Welding wire 1.0 mm weight 5 kg Dratec 2.4806
Wire electrode net weight 12 kg Böhler ER 309
Welding wire 1.2 mm weight 15 kg Magmaweld MG 2
Welding wire 1.0 mm weight 10 kg Böhler Thyssen Thermanit D
MIG/MAG hose package unbekannt 4,0 m
MIG/MAG hose package TBi 4,0 m
Bench drill MK1 WMW CM 10S/55
Machine vice unbekannt Spannweite 145 mm
Two-hand control panel with foot switch unbekannt Zweihand
Thread micrometer Mauser 75-100 mm
Gear and bevel gear measuring and testing machines
Thread micrometer Steinmeyer 75 - 100 mm
Thread micrometer Steinmeyer 125 - 150 mm
Micrometer PAV 25-50 mm
Welding wire 1.2 mm weight 15 kg unbekannt BS 300
Turntable lining Roto Record Ø 160 mm
Selfcentering- and independent chucks with 2-3-4 jaws
Saw roller block unbekannt Rollenbreite 350 mm
Volume flow transducer NOVA 9302-1161-2171-200N1
SASSEX twist drill knives 59 pieces Sassex Ø 31 - 115 mm
Saw blade WMW PWS 630 x 6 x 32  176Z
TIG welding rod 5 kg Avesta 316L-Si/SKR-Si
Jaws unbekannt 200/18/H65 mm
Jaws unbekannt 202/18/H75 mm
Jaws unbekannt 160/20/H50 mm
Jaws unbekannt 135/16/H40 mm
Activate Agent
