CERATIZIT Deutschland
394
394
Additive, innovative and totally efficient
ceratizit-deutschland news Image
PCD milling tools from CERATIZIT: The hardcore solutions
Whether manufactured using traditional processes or innovative additive technology, CERATIZIT's new range of PCD tools delivers maximum efficiency when processing non-ferrous metals and fibre-reinforced plastics. Pioneering tool features ensure a long tool life and reliable processes.
From aluminium and magnesium to fibre-reinforced plastics, PCD can handle them all! If you think that this is down to the hardness, you would be right: the synthetic diamond cutting material PCD (polycrystalline diamond) has inherited a hardness that is almost equivalent to its natural cousins. This means PCD milling tools from Ceratizit are able to hold their own against extremely abrasive materials – both in terms of tool life and attainable quality.
Hybrid tools: pioneers break new machining ground
Geometries that were difficult or even impossible to produce with conventional technologies are now a reality thanks to additive manufacturing strategies. For example, the number of cutting edges on a milling cutter can be ramped up to the maximum with 3D printing, which in turn drastically increases the chip removal rate. Once you add high cutting speeds into the mix, users stand to benefit from significantly reduced processing times. What's more, specially positioned coolant holes always supply the PCD cutting edges with the best possible cooling and remove chips quickly.
The screw-in cutters are available in diameters from 10 to 32 mm with a variable tool length using appropriate tool holders. With projection lengths of 2.5xDC, the PCD milling cutter is also offered in a hybrid design with a solid carbide base body. In order to maintain the high machining quality at all RPMs, the tools have a high helix angle that ensures quiet running.
Performance heroes in aluminium and graphite
Anyone who has to process graphite as well as aluminium will be impressed with the new PCD end mill. It uses up to four cutting edges to race through the materials at very high cutting speeds. On top of that, the end mills exhibit clear processing advantages when it comes to circular milling of holes or grooves. For example, far fewer radius corrections are required before the end of the tool life in comparison to solid carbide tools. This means the milling cutters last longer, as even the extreme abrasive conditions have little effect on them. The soldered PCD cutting edges also mean time-consuming adjustment work has become a thing of the past, which further minimises idle times and ensures constant machining quality.
More information on the new PCD milling tools can be found in the new Up2Date catalogue from CERATIZIT.
CERATIZIT – Passion and pioneering spirit for carbides
For over 95 years, CERATIZIT has been a pioneer developing exceptional hard material products for cutting tools and wear protection. The privately owned company, based in Mamer, Luxembourg, develops and manufactures highly specialised carbide cutting tools, inserts, rods made of hard materials as well as wear parts. We are the market leader in sereval wear application areas, and successfully develop new types of carbide, cermet and ceramic grades wich are used for instance in the wood and stone working industry.
With over 9,000 employees at 34 production sites and a sales network of over 70 branch offices, the Group is a global player in the carbide industry. Our international network also includes the subsidiaries KOMET, WNT, Becker Diamantwerkzeuge, and Stadler Metalle, as well as the joint venture CB-CERATIZIT. As a leader in materials technology, we continuously invest in research and development and hold over 1,000 patents. Our innovative carbide solutions are used in mechanical engineering and tool construction and many other industries including the automotive, aerospace, oil and medical sector.
We are active on the market through the seven competence brands Hard Material Solutions by CERATIZIT, Toolmaker Solutions by CERATIZIT, Tool Solutions by CERATIZIT as well as Cutting Solutions by CERATIZIT, KOMET, WNT and KLENK.
www.ceratizit.com \ www.kometgroup.com \ www.wnt.com \ www.klenk-tools.de
Published on behalf of
CERATIZIT Deutschland GmbH
Marketing \ Communications
Daimlerstraße 70 \ 87437 Kempten Germany
T. +49 831 57010-3405
F. +49 831 57010-3649
E. [email protected]
www.ceratizit.com
Responsible for the content of this press release: CERATIZIT Deutschland GmbH
