586,655 active members*
3,498 visitors online*
Login Register
DMG MORI Forum
Uncategorised CAD Discussion > Little tool to ease the CAD process
    Mar 2023
    Hey guys, I would like to share a little tool I made. It's use case is very specific, intended to help in reverse engineering (copy parts) or maybe a helper to the CNC operator to not be subjected to the cad guy for simple drawings.
    The app will take a .jpg picture and return a clean .dxf file ready for the CAM software. The DXF will consist on closed loops representing the outlines of the parts you've drawn. I'm working on the recognition of inner holes at the moment, but I tought it's ready to share.
    I'm still working on it, on the algorithm responsible for the detection so if you have suggestions fell free to contact me.
    The critical part is to have a GOOD picture, the algorithm will first look for a nice sharp good looking sheet of paper, if that step succeed it will probably return a good DXF.
    The outline will have some error, but will be well under the oxicut or plasma accuracy. Of course it is not intended for copy things like gears or parts that need a tight fit with each other... FOR NOW.
    Sorry about my english.
    https://imgtodxf.web.app/
    Jun 2015
    4155
    Re: Little tool to ease the CAD process
    hy nico, congratulation on your work
    regardless of image, contours are initally defined within a color range : all pixel colors of rgb+-tolerance are to be selected initially
    for example, take a picture, and select from it all pixels with color between 220 220 220 .. and 230 230 230
    look for color range
    begin with formats that don't loose original colors, like bmp, png; jpg quality varies with it's compresion
    let's supose your orignal image is a blue shape inside a red shape; using color range, you can extract each of the 2 separatley, then later on check if one selection is fully inside the other selection; you can do this at raster level, or at dxf level
    checking if the selection is a circle, requies also dealing with pen width, so 1st sugestion is to try images that have 1px pen widht, thus the circle has no width;
    otherwise, once the circle has width, then you should be able to detect it's inner and outside boundary, thus you will end up with 2 entities for each circle, and this will lead you to a larger situation, as for each selection for pixels drawned with >1px pen width, you will end up with 2 entitties
    check 1st how other program are working, understand what is doing each one differently, then, if you wish, particulaize it for your self
    there are inspection machines, that work on the principle or paralel-light ... they get a accurate image, but the software has no clue that the image was accurate or not, only the creation process makes it so
    in other words, if you wish, you could also make your own aporach for gears, etc
    please, feel free to ask anything / kindly
    Apr 2013
    1899
    Thank you very much. I'll try it out as soon as I have time.
  1. Process for setting tool length offsets
    By buildyourown in forum Daewoo/Doosan
    Last Post: 03-24-2023, 08:39 PM
  2. tool crib process library
    By krloscnc in forum GibbsCAM
    Last Post: 12-10-2015, 12:44 AM
  3. Tool Decomp failsafe process
    By kbarnett in forum Fanuc
    Last Post: 06-12-2012, 12:00 AM
  4. Ease of use
    By outofsquare in forum BobCad-Cam
    Last Post: 11-28-2011, 12:56 PM
  5. New In Process Tool Measurement System
    By kcoste in forum News Announcements
    Last Post: 10-09-2009, 05:59 AM
