For universal use in stainless steels
Until now, the TiNox-Cut milling cutter family has stood alone for high-performance milling cutters with finishing and semi-finishing teeth profile for machining materials that are difficult to cut, for example titanium alloys. This family of milling cutters is now supplemented by the TiNox-Cut Base series, which was developed for the special requirements of machining stainless steels. As a universal solution, the TiNox-Cut Base milling cutters represent the entry into the TiNox-Cut product line, especially for mechanical engineering, chemical and food industries.
Available in two lengths, the milling cutters focus on universal use in HPC roughing or finishing in tough materials. The special geometry with variable spacing enables smooth running and vibration-free machining.
By using the latest coatings in combination with a high-performance carbide substrate, dry machining of some rust- and acid-resistant special alloys such as 1.4301, 1.4571 or 1.4404 is also possible, depending on the milling strategy.
