ETEL S.A.
142
ETEL S.A.
142
CHARON2: New modular standard platform
etel-sa news Image
CHARON2 is a new semiconductor-oriented XY stacked system, backward compatible with existing modules and options. CHARON2 design extends CHARON use cases into the space of higher dynamics and larger payloads, with further improvement on accuracy and repeatability. Exceeding 1g acceleration and 1 m/s speed at doubled payload, while delivering an absolute positioning accuracy below 1 µm, CHARON2 represents a turnkey motion solution for state of the art new semiconductor applications and lifetime extension initiatives.
CHARON2 remains another perfect example of ETEL vertical integration, based on proprietary IP for motors, electronics and controlling know-how, and synergy with HEIDENHAIN when relating to world-class positioning accuracy feedback. The result is a broad family of solutions serving any OEM wafer-positioning needs, process or process-control related, and ranging from a core XY to a complete system of up to 9 axes, independently controlled.
CHARON2 stems from anticipated, aligned, OEM requirements immediately fulfilled with another optimized product, reducing OEM integration costs and time-to-market efforts.
Characteristics
  • Total stroke : up to 650 mm x 410 mm
  • ISO 2 clean room compatible
Main specifications
Description X (bottom) Y (upper) Theta
Position accuracy ±1 µm ±1 µm ±3 arcsec
Position stability ±2 nm ±2 nm ±0.02 arcsec
Bidirectional repeatability ±0.4 µm ±0.4 µm ±2 arcsec
Maximum payload   30 kg
Ask for the corresponding Integration Manual for more information.
CHARON2 XY 0475 x 0410 Data sheet (pdf) Interface drawing (pdf) On request
CHARON2 XYT (DXR+) 0475 x 0410  Data sheet (pdf) Interface drawing (pdf) On request
ETEL S.A.
Zone Industrielle
CH-2112 Môtiers
Switzerland
T +41 (0)32 862 01 00
F +41 (0)32 862 01 01
[email protected]
www.etel.ch
Responsible for the content of this press release: ETEL S.A.
ETEL S.A.
