ETEL S.A.
142
ETEL S.A.
142
RTMBi: Next-generation of indexing table
ETEL’s RTMB high precision indexing tables have been a trusted solution for over 10 years, with thousands of products operating in a variety of industries including automation, electronics, and back-end semiconductor manufacturing. Now, ETEL is proud to announce the next generation of high performance indexing tables: the RTMBi. By combining ETEL’s high efficiency torque motors with HEIDENHAIN’s high resolution encoder technology in a very compact package, the RTMBi delivers industry-leading torque density with high positioning accuracy.  With lower inertia and increased continuous torque, ETEL’s indexing tables are now capable of even higher dynamics and shorter indexing times, resulting in increased machine throughput for the end-user.
The RTMBi Series is a family of high precision indexing tables proposed with 5 different active lengths. Integrating ETEL direct drive torque motors, the RTMBi Series benefits from the best motor constant on the market (Nm/√W) allowing very high acceleration during indexation with low power dissipation. The RTMBi Series is the ideal standard solution for all applications where high repeatability and short indexing times are required. This highly reliable direct drive solution allows high duty cycles, high dynamics, outstanding accuracy, low maintenance and easy integration.
A unique encoder-bearing solution provides the RTMBi series with the best torque to volume ratio on the market. An optimized hollow shaft size is available to accommodate customer cables and tubing. Alone or coupled with ETEL’s force controlled short stroke actuators and AccurET controllers, the RTMBi is the perfect solution for applications in back-end semiconductor manufacturing, electronics, automation, or printing, such as MEMS testers, die bonders, pick and place testers, turret testing handlers, and more!
RTMBi series
Characteristics
  • Rotary tables for high dynamics indexing applications
  • 5 different heights
  • High torque to height ratio
  • High dynamics capabilities
  • Large hollow shaft for maximal flexibility
  • TMB torque motors technology providing high level of torque.
RTMBi vs. RTMB
  • Continuous torque improved by up to 15%
  • Inertia reduced by up to 20%
  • 600 VDC compatibility
  • Same mechanical interface
Main Features
  • Bidirectional repeatability ±5 arcsec at ±3sigma
  • Position accuracy
    - ±25 arcsec (w/o mapping)
    - ±6 arcsec (w/ mapping)
  • Speed up to 1200 rpm
ETEL S.A.
Zone Industrielle
CH-2112 Môtiers
Switzerland
T +41 (0)32 862 01 00
F +41 (0)32 862 01 01
[email protected]
www.etel.ch
Responsible for the content of this press release: ETEL S.A.
ETEL S.A.
