588,199 active members*
4,741 visitors online*
Login Register
FANUC Forum
General Off Topic Discussions > Mach 3 / CNC Router help
Results 1 to 8 of 8
    Apr 2014
    4
    My name is Barry and I have just purchased my first CNC router and associated software.
    I am a complete novice re CNC and expected some teething issues but I think I would have more chance of launching a space shuttle than getting my machine to work!
    I am using RhinoCad with a 3rd party program, which is then linked to meshcam and then to Mach 3. No major issues with Rhino or meshcam but I purchased a router from China (1/5 the cost of comparable Australian machine) and requested and received Mach 3 from same supplier. It came on a generic CD which contained the files which I loaded onto my computer. The Mach 3 opens and seems ok but I cant find anywhere to configure my router.
    Installation guide tells me to add an xml file to folder if I have one -will this bypass the need to configure everything manually? Of course I dont have an xml file!
    Router is too big to convert to a coffee table so I would really like to get it working
    Any help would be greatly appreciated.
    Cheers
    :cheers:
    35538
    Re: Mach 3 / CNC Router help
    If you didn't receive an .xml file with all the settings, then you'll need to configure everything manually. Do this by going to Config > Ports and Pins and entering the pin and port numbers for your motors and switches.
    Apr 2014
    4
    Thanks Gerry - I assume the xml file comes from the machine manufacturer. Are they a standard type that would apply to any milling software or are they a dedicated file for Mach 3?
    35538
    It's a special Mach3 configuration file, that stores all the Mach3 settings. The machine manufacturer is where you'd get it, or from someone with an identical machine.
    Apr 2014
    4
    Received .xml files from router supplier, installed and machine is now talking to Mach 3
    I am able to move all axis with jog controls but they dont seem to stop until it bogs down at end of range. Should there be stops programmed at edges of actual machining area?
    I am trying to work out how much I need to learn about Mach 3 configuration given that I am using meshcam as a link from RhinoCad
    Any advice or direction would be greatly appreciated..
    35538
    You can set up Softlimits in Mach3 to stop motion at the ends of your travel. For softlimits to work correctly, you'll need Home switches to provide a repeatable machine coordinate system.
    Since mach3 controls the machine, you at least need to learn about work coordinate systems and how to zero the axis.
    Apr 2014
    24
    The machine shouldn't continuously move without you pressing the GUI button on the jog control. If it does you need to find the setting to make it just move when you press the button. If your moving it with manual gcode inputs, make sure you don't input coordinates that are beyond the capability of the machine. The little dot to the left of the three distance windows zero the axis's. I normally setup my machine to work from zero at the bottom left of the table.
    Oct 2013
    8
    When you start Mach 3 are you starting it using the Mach 3 loader?
  1. Use Mach/G540 to turn on router
    By Brian@Premier in forum Gecko Drives
    Last Post: 04-26-2014, 04:16 PM
  2. I Need help configuring a used 4x8 router and mach 3
    By joecnc1 in forum DIY CNC Router Table Machines
    Last Post: 11-29-2013, 10:25 PM
  3. Router and Mach 3 stopped talking!
    By vcustomshop in forum DIY CNC Router Table Machines
    Last Post: 11-17-2012, 07:57 PM
  4. Trouble with my configuring mach 3 for my cnc router
    By functionbikes in forum Mach Software (ArtSoft software)
    Last Post: 03-04-2009, 01:17 AM
  5. Mach 3 and router tables???
    By bgriggs in forum Machines running Mach Software
    Last Post: 10-22-2007, 05:33 AM
