587,958 active members*
3,771 visitors online*
Login Register
FANUC Forum
UCCNC Control Software > UCCNC Macro sharing
Page 1 of 4 123
Results 1 to 20 of 65
    Dec 2010
    634
    UCCNC Macro sharing
    I thought I'd start a thread where we can share our macros. I'll start by sharing the macros I made.
    USE AT YOUR OWN RISK!!!!
    First combo are M31 and M6 for auto tool length measuring after a manual tool change. When running a part, you use a mobile Z-touch plate and a fixed touch plate. M31 will probe down at the current location, then retract and move over to the fixed plate and probe. It then calculates the difference between Zzero and the fixed plate and stores that value in the C-axis DRO for later use by the M6 macro. Z-zero is set to the same value for offsets G54 to G59.
    The M31 macro also supports a "material offset" which can add or subtract an amount from Z zero. If this is non-zero when you call the macro, a message box will come up to remind you that it is non-zero.
    The M6 macro stops the spindle and then moves to a tool change location. Once you're done changing tools, hit return or click ok and the machine will move to the fixed plate, probe down and set a new Z-zero for all offsets.
    You must customize the macro by entering the coordinates of your tool change position, fixed plate position, Z-setting plate thickness etc. etc.
    Remember, USE AT YOUR OWN RISK!!!!
    I'd ask that if you make any improvements or modifications that you please post back to this thread so that everyone can benefit.
    Attached Files Attached Files
    -Andy B.
    http://www.birkonium.com CNC for Luthiers and Industry http://banduramaker.blogspot.com
    Dec 2010
    634
    Re: UCCNC Macro sharing
    This Macro is a simple Z-zero probe. Machine probes down and sets z-zero for all offsets. I named it M200 and it can be accessed by pressing the P1 button and the default screen.
    -Andy B.
    Nov 2006
    40
    Thanks for these Andy, I've just bought a copy of the software and recently e-mailed Balazs regarding more hotkeys to run macros such as homing, probing, start cycle etc. He said there will be 48 in the next version of UCCNC.
    Mark
    May 2015
    @BanduraMaker
    Very interesting macros..
    Where do you find reference documentation for this (and other similar) line of code?
    exec.mainform.sumoffsetcontrol1.G59.newCcinput
    Michele
    Dec 2010
    634
    I didn't find them actually, I emailed Balazs from UCCNC and told him what I needed to do, he gave me the line of code to do it. There's a couple variations on setting offsets so there may have been some back and forth.
    -Andy B.
    Mar 2014
    735
    I implemented BanduraMaker's auto tool length measuring macro a few months ago and after some minor customizations for my machine and a few emails to Andy I got it to work. And it works great! makes using the machine much easier. Thanks Andy!
    Aug 2006
    143
    Has anyone here migrated from Mach3 to UCCNC? I have a number of custom macros I want to convert from VB to C#. I'm not well versed in either but I thought that it would be nice to see if anyone else is converting.
    Derek
    Dec 2010
    634
    Yes, I converted from Mach 3 to UCCNC. The macros I posted were the main ones I was using in Mach 3
    -Andy B.
    Aug 2006
    143
    Actually your name just poped up on the mach forum. I'm trying to get some momentum for people switching from Mach to UCCNC under the theory that the more users the more development
    Gerry said you converted the macros from his 2010 screen set. Have you modified the UCCNC screens for the probing routines that are in the 2010 screen set?
    Jul 2015
    34
    I was just on the Mach Forum and would like to convert to UCCNC but need Gerry's 2010 screenset conversion. Can you post the files?
    Feb 2008
    Looks like the macros are in the first 2 posts above.
    Also, a link to how to change/select different screen sets.
    I'm liking the looks of the UCCNC and might just try one myself.
    Thanks,
    Kar
    Jun 2007
    27
    hi, is there a way to change the value of a variable like #500
    in a gcode within a macro file?
    something like this:
    #500 = exec.GetZpos();
    thamks
    Cahit
    Oct 2005
    1145
    I am sure there may be several ways but this come to mind as one way. I am very new to UCcnc and C# scripting (;-)
    exec.Code("#500 =" + exec.GetZpos() )
    (;-) TP
    Jun 2007
    27
    i got a mail from Balazs, he's solution was:
    exec.ivars[500] = exec.GetZpos();
    Thanks Balazs!!!!
    Jun 2007
    27
    Hi vmax,
    it seems logical, and i tried it but does not work.
    and what Balazs wrote is working as an horse (dutch proverb)....
    also you can put a variable in stead 500.
    very very cooool.....
    regards
    Oct 2005
    1145
    It should have been exec.Code("#500=" + exec.GetZpos() );
    (;-) TP
    Jun 2007
    27
    oh yes i see there was missing a semicolone.. it works also....
    thanks
    Oct 2005
    1145
    HI Guys I am looking all the Probing scripts and I do NOT see where anyone is actually retrieving the Trip Variables. As I see it you cannot use Axis Position values for trip values. The probe cannot instantly STOP at the trip point it has to deexcellerate to a stop so the trip point and the stop point are 2 different values.
    Does anyone have a list of all the useable System #vars ?? OR are there NONE created yet ??
    I am starting to work on porting all the known M3 probing routines over to UCcnc.
    (;-) TP
    Dec 2010
    634
    For my macro, The final probe is at 1ipm and although you're right about the instant stop, at 1ipm it's close enough for what I'm doing and will get me within .001" of repeatability. The bigger issue I think is have the machine perfectly trammed and the fixed probing plate trammed as well. That seems to cause more error than using Axis position for the probe value.
    All that said, I'm working with wood so what might not be a problem for me might be a problem for folks using more accurate machines and materials.
    -Andy B.
    Oct 2005
    1145
    As long as it works for you THAT is all the matters(;-).For the record there are 3 basic things to account for with a probe.
    Tip radius
    Center of tip to center of spindle offset In XY
    Switch travel until trip.
    They can ALL be tested with the simple ball and post test to generate the values to calibrate the probe.
    (;-) TP
Page 1 of 4 123
  1. UCCNC owners and support thread
    By shorton in forum UCCNC Control Software
    Last Post: 08-25-2017, 12:07 AM
  2. Getting Started with UCCNC Software
    By BanduraMaker in forum UCCNC Control Software
    Last Post: 02-08-2015, 07:06 PM
  3. UCCNC software released for sales
    By dubble in forum News Announcements
    Last Post: 08-05-2014, 11:25 AM
  4. UCCNC software release
    Last Post: 06-13-2014, 02:24 PM
  5. Sharing a tool offset verification macro
    By dpuch in forum Parametric Programing
    Last Post: 08-02-2010, 09:46 PM
