587,303 active members*
3,780 visitors online*
Login Register
FANUC Forum
HURCO > Does anyone have a real schematic for the Hurco Control Relay board (pcb)
    Feb 2007
    592
    My KM3 has Hurco P/N 415-0144-004C for the 8 Icecube relay board which has TB3 and TB2 on it.
    My documentation has drawing 002-2474-001,002,003 Rev E - Which for all practical purposes is total garbage as it references TB8, TB9, TB10 none of which existed in my machine.
    The documentation from my KM3P - is more accurate - but again is specific to that machine with spindle speed feedback and setting.
    What I would really like is a PCB schematic - Not a labeled wiring diagram which lists what was hooked to what.
    AS in - Which TB3 terminal numbers are the activation coils for each relay, which terminals for the NC contact 1 & 2, Which contacts for the NO 1 & 2 etc ad nauseam.
    The MAX II card rack and power supply are gone and I am replacing with a PC with Mesa 5i25 + 7i77 and industrial 5VDC and 24VDC power supplies.
    My goal is to be able to use the existing CRB to latch Servo power on and wire it such that E-stop drops the latch. I also hope to use the FCV, MCV, and BRK functions... ( Flood & mist coolant and spindle air brake relays)
    Spindle will be run by VFD so the 2 Relays which drove the spindle contactors won't be used.
    Jun 2008
    1104
    Re: Does anyone have a real schematic for the Hurco Control Relay board (pcb)
    I've got a schematic of the board you have. Want it mailing?
    Feb 2007
    592
    Please - Very much so. A pint with a shot on top even!
    Email is the name @yahoo.com
    Jun 2008
    1104
    Right-o. I'll send it when I'm back at my PC in the morning.
    Feb 2007
    592
    WoW - Thanks - That package was a nice Swiss Army Knife of info which helps a bunch. My 87 KM3 had a blue console and I was latter told there were maybe a dozen of the first dual displays after the BX control that were blue before normal production made them all black.
    The KM3p is a 1990 that started life as a MaxII but was later retrofitted with the MAX32 upgrade and it has the Max400 amps while the 87 has a CMC Servomate amp rack.
  1. Looking for a CNC schematic board
    By MASNSN in forum Mentors & Apprentice Locator
    Last Post: 06-03-2012, 07:51 AM
  2. Real Time Board
    By technetics in forum Cincinnati CNC
    Last Post: 12-16-2009, 07:01 PM
  3. Sieg C2 motor control board schematic?
    By HankMcSpank in forum Mini Lathe
    Last Post: 09-09-2009, 09:13 AM
  4. Replies: 6
    Last Post: 10-22-2008, 04:40 PM
  5. Hurco DSP/Matrix 4 Control Board Repair
    By mjl in forum News Announcements
    Last Post: 06-27-2008, 12:07 AM
