588,504 active members*
4,956 visitors online*
Login Register
FANUC Forum
Mach Software (ArtSoft software) > Mach 3 issue - possbily arc gcode related
    Feb 2007
    14
    I've had my 4'x4' router going now for about 3 months - not my first machine but my first mach 3 machine. It has seen about 100 hrs? of use without a problem( that I couldn't figure out). Last night I was running a program and it previewed OK - had a couple stray circles, but those have never cause a problem in the past. About 4000 lines in it plunged my Z axis straight down through my table. I was able to repeat this 3 times at the same spot( not close to one of the stray circles). I removed approx 20 lines of code and it pass right by. It was programmed by mastercam 7, which generates lots of G02,G03 arc commands.
    Could mach3 be having a trouble with a arc command that causes the z axis to plunge like that. The strange part is - when I stop it right before it hits the table the DRO's are still at the old position.
    Anybody else have this problem, what was a cure? Loosening the tolerances in Mastercam maybe so the arcs have a smaller radius?
    Fred
    Jun 2007
    3735
    Question Have you tried..
    Have you tried disastercam? It does the same. Also generates multiple moves in the same direction. That's enough to give the g-code processor so much to do that the queue gets emptied, while moving in a straight line. The cost might be proportional to the extra code. I love hand coding, or learning lisp.
    Feb 2007
    14
    Ok,
    After some more testing I might have answered my own question. After posting out the files in line segments instead of arcs. I still had repeatable crashes - (always on the z which is weird). If I slowed down the program 25% if would run right by the lines of code that appeared to cause the crash. No the code problem then probably. Logged a couple CPU graphs. - appeared to be running about 80-95% when running full speed and about 50% when slowed down to 25-50%. At this point I think a "spike" is causing the problems.
    FYI
    Almost all the previous programs were run about 200 in/min and programmed by Artcam. This last batch is running 400-800 in/min and programmed by Mastercam.
    Fre
  1. Replies: 6
    Last Post: 01-12-2007, 05:42 PM
  2. Help with selector switch wiring issue (***actually a motor issue***)
    By BEDFORD in forum Charter Oak Automation Support Forum
    Last Post: 04-07-2006, 09:19 PM
  3. Mach 3 reacting to my GCode crazy!
    By WarrenW in forum Mach Software (ArtSoft software)
    Last Post: 02-19-2006, 10:44 PM
  4. Mach 3 GCode Question
    Last Post: 01-10-2006, 07:43 PM
  5. Mach / GCode question
    Last Post: 11-19-2005, 08:21 PM
