586,105 active members*
3,272 visitors online*
Login Register
FANUC Forum
Okuma > LB15 spindle motor check need help
Results 1 to 2 of 2
    Jan 2011
    Hi everyone. I'm the guy that was having trouble with a Fanuc AC spindle drive on his LB15. Originally got SDU-1 alarm, Fanuc F7 alarm (blown fuse), pointing to shorted Transistor modules. Presumably I blew them from a large voltage drop from the line to the Phase converter running the lathe. I replaced the bad transistor modules and believe that I got all the wiring correct. ( labeled everything and didn't take it all apart at once ).
    Now with better service wire coming from the house. When I did a spindle command now I'm getting a SDU-1 alarm and alarm 12 on the Spindle drive unit which points to 'check wiring', bad transistor modules ( already changed them ) or a shorted spindle motor.
    I need to know how to check the winding of the motor. Fanuc AC spindle motor model 8 A06B-1008-B902.
    Any help greatly appreciated!
    Jul 2007
    143
    Did you resolve the issue, what did you find?
  1. Please check my Spindle settings. I can't get Mach 3 to run my spindle
    By TheProCreator in forum Mach Software (ArtSoft software)
    Last Post: 09-07-2013, 05:50 AM
  2. Okuma LB15 spindle motor problem
    By JINX222 in forum Okuma
    Last Post: 03-20-2012, 06:07 PM
  3. okuma lb15 spindle drive unit
    By TTT in forum Okuma
    Last Post: 02-03-2011, 03:49 PM
  4. LB15 Spindle Motor Cooling Fan
    By JonLed in forum Okuma
    Last Post: 02-23-2009, 09:52 PM
  5. okuma LB15 spindle drive unit
    Last Post: 03-17-2008, 12:51 PM
