586,103 active members*
3,420 visitors online*
Login Register
FANUC Forum
Drilling > 4mm through drills in 16mm SS balls
Results 1 to 5 of 5
    Nov 2019
    5
    We are facing issues while drilling 16mm SS 304 balls in a CNC Machine.
    We initially used HSS drills but we were facing some issues with that. Then we moved to Carbide drills, but still, we face issues like tool breakage and tool wear. We are only machining 50-60 balls and then we need to change the drill. What are we doing here?
    How do we solve this issue?
    Jun 2015
    4154
    Re: 4mm through drills in 16mm SS balls
    exactly ... you couldn't have ever said it better
    cut a face before drilling, so to make sure that the drill is starting on a surface that is perpendicular on it's axis, and also to minimize the start cutting load, since material crust, in most cases, is harder then the core
    through coolant
    rigid fixture & tool clamping
    aligned tool & machine
    use load monitor ( and/or listen carefully ), to detect load peeks; they should occur as depth increases, and, if so, manage them by pecking/full retraction
    a 3D drill should be enough, as most tool sizes are allready standard : flute length ~24, active length ~17
    in order to improve hole cylindricity near the end (+ extend tool life), it may be required to reduce feed right before the tool is piercing out
    kindly yet again, what are we doing here ?
    Jan 2007
    626
    You can't do this in a manual lathe?
    Nov 2019
    5
    We did use carbide center drills before the drilling operation and we used through coolant as well. Still, we were facing some issues.
    Apr 2017
    29
    Quote Originally Posted by Eosprein View Post
    This from Deadly Kitten "cut a face before drilling, so to make sure that the drill is starting on a surface that is perpendicular on it's axis, and also to minimize the start cutting load, since material crust, in most cases, is harder then the core"
    Do not use centre drills with Carbide Drills . A Flat face is preferable . A 90° Centre to a 136° Carbide Drill just causes notching on the cutting edge leading to breakages .
