586,115 active members*
3,429 visitors online*
Login Register
FANUC Forum
Okuma > HELP NEEDED - OKUMA LB 10 ATC - Page 2
Page 2 of 2 12
Results 21 to 31 of 31
  1. #21
    Mar 2004
    136
    Re: HELP NEEDED - OKUMA LB 10 ATC
    Anyone have a okuma LB 10 Parts manual ?
    Id like to see the Turret in an exploded view , just see what im dealing with .........
    Anyone ??
  2. #22
    Mar 2009
    1982
    is the parameter tool number ( how many indexing positions the turret has ) right?
  3. #23
    Mar 2004
    136
    On one of the pages it shows switch positions. ie. On or off
    There are 12 tools and seven switches
    That work on a cam system ..
    It's a 80s machine
    I think I'll pull the turret off as I'm sure there is something going on inside , making it stick etc
    If anyone has a diagram of the turret ?????? Thanks in advanced
  4. #24
    Mar 2004
    136
    I have managed to find a Diagram of the turret.
    Can anyone give me ideas as to how i take off the TURRET ( rotary carousel that holds all the tools).
    I have attached a photo of the Turret and a screen shot of the parts manual......
    All the bolts on the turret are off and the thing is not moving, Im thinking i need like a bearing puller to move it
    Any ideas ??? anyone ?Attachment 501490Click image for larger version.
ID:	501492Click image for larger version.
  5. #25
    Mar 2009
    1982
    check the rear side. Maybe cylinder still holds it.
  6. #26
    Mar 2009
    1982
    are tapers ( pins ) removed?
    I guess, you need to release the draw tube at the cylinder end and remove it pulling to the front.
  7. #27
    Mar 2004
    136
    Looks like the taper Pins are not there, very hard to tell. Are taper pins hollow ? generally ?
    I can stick a 6mm drill through the hole.
    But when looking at the hole can see like a bush inside ?
    So , sounds like stupid question but are the taper pins hollow ?
  8. #28
    Dec 2008
    3109
    Quote Originally Posted by jubee View Post
    Nah, not a silly question....
    They have a thread to allow various forms of extraction.
    (ie. Screw + washers, pulling the pin thru a spacer.... or, to allow use of a "slide hammer").
    Pins are used to roughly align a drill holder to the spindle, & then removed for final alignment. Having no pins allows the turret to "slip" if any heavy crash occurs.
    This is how X zero is referenced as machine origin.
  9. #29
    Mar 2004
    136
    Great information , thank you
    I will have another look today, I can't say I saw any thread where the taper is / was But will take a better look.
    Once I start getting to the pieces all will become clear. Looks like I may have to apply some heat to the centre section of the turret to pull it off as I can see slight rust on the shaft ...any problems in doing this ??? Apart from maybe wreaking some o rings??
  10. #30
    Mar 2009
    1982
    check twice.before heating.
    As per illustration, are the flange 10 and pipe 11 removed? and again flange and pipe 7 and 8 ?
    or maybe the real thing looks different from the picture?
  11. #31
    Mar 2004
    136
    No, the Flange 10 and pipe 11 is still on , but i cant see how they would attach or keep the turret from separating.
    Further inspection and the taper pins or where they go i cant see any thread so i think the taper pins are removed
Page 2 of 2 12
  1. OKUMA LB10 ATC
    By jubee in forum Auto Tool Changer
    Last Post: 02-01-2022, 10:29 AM
  2. Need help okuma osp5020 ATC problem
    By cic108 in forum Okuma
    Last Post: 06-10-2014, 03:46 PM
  3. Newbie to OKUMA - ATC problem
    By thomasunique in forum Okuma
    Last Post: 06-24-2010, 01:23 AM
  4. okuma ATC - stuck
    By conveyor in forum Okuma
    Last Post: 01-29-2008, 03:29 AM
