586,112 active members*
3,110 visitors online*
Login Register
FANUC Forum
BOSS Laser > Boss LS1416 - machine only beeps and LED screen is dark (not on) when powered up
Results 1 to 2 of 2
    Nov 2022
    Hello.
    I have a LS1416. Did 2 jobs (coated tumblers using rotary tool) early yesterday and shut it down.
    When I turned laser back on to do another job yesterday afternoon, the laser light came on, the laser started to beep, the head went to back right, then 6" towards the front and 2/3's of the way to left, then stopped.
    The machine simply beeps, the LED screen is dark, so there is no way to access anything.
    I've searched the internet, called and emailed Boss support, but wanted to reach out and see if anyone had any ideas of what happened.
    Thanks in advance.
    Jun 2005
    1730
    Re: Boss LS1416 - machine only beeps and LED screen is dark (not on) when powered up
    You might want to open the control panel and check the voltages at the power supplies using a meter. Also check for any blown fuses
