586,075 active members*
4,360 visitors online*
Login Register
FANUC Forum
EnRoute > 3D Routing offset
    Oct 2022
    9
    3D Routing offset
    Hi Folks,
    I have some curved pressed ply blanks that I need to cut backrests and seats from, ie an outline. Im wondering if theres a way to do a simple routing offset outline with a 3d lift and plunge along the curve. I could do it in 2 open contour offsets and calculate the 3d entry and exit lengths but a single profile would make life easier.
    Is there a way to do this in enroute? All the 3d cutting tutes ive found have been for carving complex forms with 3d reliefs.
    Cheers!
    Jan 2021
    10
    Re: 3D Routing offset
    I do not believe there is a simple way to do in versions enroute without 3D enabled, as that sounds like a job for enroute's 3d options:
    where you would clamp your panels with a jig to the table, take as accurate measurements as possible, & use the extruding tools program the base-shape/curve as a solid convex-shape, extrude your reliefs above this, and export your toolpaths along their paths.
    I believe they still offer a free trial of their new softwares via Sai website if you want to tinker around and give it a shot.
  1. Replies: 9
    Last Post: 04-03-2024, 09:33 PM
  2. Replies: 11
    Last Post: 12-17-2016, 04:59 AM
  3. Replies: 1
    Last Post: 05-22-2016, 10:59 PM
  4. Tool offset with work offset
    By botha.y in forum SIEMENS -> GENERAL
    Last Post: 05-28-2012, 09:48 PM
  5. Replies: 2
    Last Post: 05-25-2009, 05:22 PM
