586,119 active members*
3,557 visitors online*
Login Register
FANUC Forum
UCCNC Control Software > UC400ETH HY VFD Control
Results 1 to 10 of 10
    Ive just got my CNC milling machine all working finally. Im just stuck on being able to control the speed of my spindle.
    I have a UC400ETH motion controller from CNCdrive with the UCSB breakout board. Which does not output an analog signal which I require to send to my HY VFD. My VFD can accept 0-5V analog which from what I was reading I could put in an RC (Resistor & Capacitor) circuit to smooth the PWM output of my motion controller into a readable analog voltage for my VFD.
    I have tested this with a 10k resistor and 5uF capacitor but with no luck.
    If anyone has done this before with any success I would love some help if possible. Or any alternatives like PWM to Analog control boards.
    Cheers,
    Rohan
    Re: UC400ETH HY VFD Control
    Quote Originally Posted by KiwiEngineer View Post
    Cheers,
    Rohan
    Is it possible to use pulse instead of analog?
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    I dont believe so? I dont have any experience programming a VFD. I currently have PD070 set to 1. Is there a way to run the HY VFD's with PWM?
    15362
    Ther have been that some have used the HY VFD Drive with PWM I don't know if this was correct or not, as their signal may have been converted to analog and they did not know it.
    What most do is used a simple addon converter which you can find quite inexpensive, something like the attached snip, you can find them on Ebay / Amazon Etc.
    Yes, this VFD Drive only has normally 0-5v / 0-10v Analog input for speed control!
    This small board can use Step /Dir and output of 0-10v Analog so there are some choices you have.
    https://cnc4pc.com/motion-control/mo...rol-board.html
    Mactec54
    15362
    Cheers,
    Rohan
    Did you have all the correct Parameters set when you tried it, the J1 Jumper also has to be in the correct position for remote control.
    Mactec54
    Hi Mactec54, I think i have found one of those converter boards so i will hopefully get that setup soon. My only settings i set are as follows. Hopefully are correct haha.
    PD001=0 (1 For Remote Control)
    PD002=1
    PD003=50
    PD004=50
    PD005=50
    PD006=2.5
    PD007=20
    PD008=415
    PD009=15
    PD010=8
    PD011=30
    PD014 Acceleration=3
    PD015 Deceleration=3
    PD023=0
    PD120=100 ( Stall Prevention )
    PD141=240 (Wired in delta)
    PD142=7.5
    PD143=2
    PD144=2860
    PD070=1
    PD072=50
    PD174=10
    15362
    PD002=1
    PD003=50
    PD004=50
    PD005=50
    PD006=2.5
    PD007=20
    PD008=415
    PD009=15
    PD010=8
    PD011=30
    PD023=0
    PD142=7.5
    PD143=2
    PD144=2860
    PD070=1
    PD072=50
    PD174=10
    PD08=240
    What is your Mains Power supply voltage and what is your motor specs?
    Mactec54
    Yes PD08=240. Sorry i remember having to change a few when i programmed it.
    Our mains power is 230v-240v 50hz.
    I have attached a picture of the motor. It is a 2 pole motor fyi.
    Sorry the imagine is hard to see. I coudlnt get a right angle.
    Cheers,
    15362
    Cheers,
    Ok so all the parameters that you have set at 50Hz you can use up to 100Hz 80Hz would be a good starting point and see how the motor runs this will give you double the RPM when using 100Hz, so if the Bearings and the Balance are good you can have more RPM note the torque will be less than the base name plate speed as the RPMs go higher
    PD011= 30 these are minimum speed watch for temperature and Amp draw at this speed you may be ok to go as low as 20Hz
    PD073= 30
    PD041= 6 to 8 Carrier Frequency check Temperature when using higher numbers
    PD144= may need to be 3000 to get to the higher RPMs
    Mactec54
    35538
    The easy way is with the HY modbus plugin and a $10 USB-RS-485 converter.
    Huanyang VFD Macro/ Plugin
    Direct Link to the plugin. http://www.cnczone.com/forums/attach...2&d=1496484048
  1. UC400ETH Issues.
    By Atom22 in forum SmoothStepper Motion Control
    Last Post: 11-01-2021, 02:04 PM
  2. UC400ETH Not Connecting
    By Seitz333 in forum UCCNC Control Software
    Last Post: 07-12-2018, 01:28 AM
  3. Break out board with spindle control for use with a UC400ETH
    By planeflier in forum Stepper Motors / Drives
    Last Post: 11-04-2017, 03:59 PM
  4. Replies: 1
    Last Post: 01-04-2014, 01:43 AM
  5. Modbus TCP with Control Techniques SK Commander VFD for spindle control
    By fishin_fl in forum Mach Software (ArtSoft software)
    Last Post: 08-26-2013, 04:07 PM
