Re: Working to get VM16 up and running
Originally Posted by
hods1222
Hello all, I need a little help. I am a new owner of a 1997 VM16 with a Centurion VI control and could use a little help. The machine had a bad CMOS battery in the Dallas chip. It wouldn't let me move past that portion of the bootup so I have went thorough and replaced the chip with a socket to help with any future need to replace. I was able to put everything back in and connected but now it is giving me a "operating system not found" error. What is the best way to mitigate this condition to get it up and running. I would like to keep the Centurion control and could use some expertise.
Also, from what I can tell, these machines can be ran on single phase. I have a Rotary phase converter but if I can just plug this into the wall, that would be even better. I understand that it would be de-rated, and thats OK. The machine is a VM16 Series B serial number 4173 manufactured 7-14. From reading on another post, It looks like I can connect the lines to L1 and L3. But there was talk of a jumper...is that just a jumper wire from L1 to L2?
Thanks for the help in advance.
This VM16 machine is too old now, even these two problem solved but many problem could coming on the way.
But the machine body should be still good, better change a new CNC retrofit package.
http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
