586,104 active members*
3,276 visitors online*
Login Register
FANUC Forum
UCCNC Control Software > Problem probe AXBBE UCCNC
Results 1 to 1 of 1
    Dec 2022
    I am French, and I'm new to using UCCNC software. I have an AXBBE control card, and I need your advice on installing my probe.
    It's an NPN and has 3 output wires: signal, + and -. I connected it as in the diagram in the AXBBE manual (the signal from my probe, on l1- and the + to my probe on l1+ ( AXBBE) and 24+ to my powersupply. The - of my probe is on negative of my powersupply). My probe seems to work because it lights up green, then red when I create a contact.
    UCCNC detect my probe, there is green led on "probe" and "l1" when I connect it, and when I push "probe" button, Z axis go down and go up immediately, as if my probe was already actived and detected contact.
    I don't know if it's a connection AXBBE or configuration problem in UCCNC...
    Thank you in advance for your advice.
    Nov 2023
    Re: Problem probe AXBBE UCCNC
    Italian with English from Google.
    I don't understand if you are referring to the piece zero probe, npn limit switch or to the probe.
